Slow speed fan is dead
Old Feb 7, 2013 | 08:35 PM
forum009's Avatar
forum009
Hey everyone,
The slow speed fan on my '03 Cooper is dead. My car has a build date of 12/02, according to many sources, I will likely need the fan with 2 wires. The cut off line is supposed to be 3/03, but I read some 2/03 owners has the newer 1 wire fan in their car.
Question is, before I order the new fan, is there a way to determine whether I should order 2 wire vs. 1 wire without taking the front end apart?
Your wisdom is deeply appreciated.
Old Feb 7, 2013 | 11:20 PM
Eric_Rowland's Avatar
Eric_Rowland
The connector is on the upper right of the fan assembly as you face the car. You should be able to see it without taking things apart.
Old Feb 8, 2013 | 03:09 PM
minsanity's Avatar
minsanity
If you still have high speed, squeeze the life outa your stock fan. If you have the 2 plug set up, you can do the same bypass I did here:
https://www.northamericanmotoring.co...r-surgery.html
I'd bet your stock fan will probably last longer than a new fan's resistor. When low is called, I get high speed. A/C & engine are now cooler!
rob&JCW
Feb 13, 2023 07:03 PM
theblackfalcon
Oct 11, 2015 09:49 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
David.R53
Sep 1, 2015 06:51 PM
Aug 12, 2015 01:24 PM
