R50/53 Steel Rim size... help quick.
Old Feb 7, 2013 | 08:05 PM
GreekDrifter91's Avatar
GreekDrifter91
i need to find a new steel rim i know they are 15" and 4x100 rims but what i don't know is the rim width and the offset, and hub diameter..
Old Feb 7, 2013 | 08:33 PM
Grahams315's Avatar
Grahams315
I believe my winter wheels are 6inches wide and a 35 offset. Hope this helps.
Old Feb 7, 2013 | 09:00 PM
mini coop's Avatar
mini coop
OEM wheels in 15 inch are is 5.5" wide and have a 45mm offset. I believe the hub is 56.1mm.
Discounttiredirect.com has steel wheels for Mini's for about $55.00 each. Also have free delivery.
Old Feb 8, 2013 | 07:38 AM
GreekDrifter91
Originally Posted by mini coop
OEM wheels in 15 inch are is 5.5" wide and have a 45mm offset. I beleive the hub is 56.1mm.
good to know. really they are only 5.5" wide? the tire i have on now is a 175/65 15. if that helps at all determine what size rim i have
Old Feb 8, 2013 | 08:24 AM
GreekDrifter91
does it say anywhere on the rim what the width is? discount tire says they are 6"... i dont want three 5.5" and one 6"
Old Feb 8, 2013 | 08:49 AM
Capt_bj's Avatar
Capt_bj
http://www.outmotoring.com/mini-15-steel-wheel.html
Old Feb 8, 2013 | 08:56 AM
GreekDrifter91
just went and looked and rim says 5.5J x 15H2...... what are the letters for? anything special? or will any 5.5"x15" rim do?
Old Feb 8, 2013 | 03:45 PM
cristo's Avatar
cristo
Alliance Member
The J is the bead profile (J is pretty standard) and the H2 is the hump profile (H2 is double hump).
Read more here:
Old Feb 8, 2013 | 04:55 PM
mini coop's Avatar
mini coop
175/65/15 is a very thin tire and the reason for the 5.5 inch width. You can fit up to a 205/55/15 tire on the rim though if you ever wanted to. I had that and it was aggressive looking. Handling was great too.
Old Feb 8, 2013 | 05:23 PM
GreekDrifter91
Read more here:
thanks!
i ordered a rim all ready so im good now just got to wait for it to come in.
Doc Pain
Mar 10, 2021 04:50 AM
luisfv56
Nov 16, 2015 01:55 PM
malibujoey
Nov 9, 2015 08:22 PM
Winston46
Nov 9, 2015 06:18 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
