R50/53 My ’03 Mini R50 @ 200K
Old Feb 7, 2013 | 09:53 AM
Lowell's Avatar
Lowell
Just turned 200K on the odometer and still running strong. I am the original owner and 95% of miles put on my Coop was from commuting on Highway 1, a two lane coast road w/many twists, turns, and hills. Started off at 38 mpg, now down to 33-34 mpg (probably be better if I replace the O2’s). In other words, it is the absolute perfect car for me.
Replaced – Radiator & Water pump @ 89K
Replaced – Power Steering pump @ 102k
Replaced – brake pads @110K
Replaced - #1 Exhaust Valve @ 195K
Replaced – Alternator & fan belt @ 197k
On my 7th set of tires
Changed oil and filter every 6-7K.
“Motor has never overheated.”
Annoyances – At 35K, right side Xenon headlight would not fire off right away and must recycle on/off switch many times in most cases to get it on. Fixed once on warranty, but problem immediately returned & persists.
- Check Engine light constantly on due to O2 sensor. Replaced once at extreme cost$$$.
Future Worries... Replacement of clutch & timing chain...?
Old Feb 7, 2013 | 09:59 AM
Dale Williams's Avatar
Dale Williams
03 R50 195K miles
Had clutch fail at 185K, No issues with O2 sensor, engine valve or Power Steering pump yet. Maybe 5 sets of tires ,other repairs similar to yours
Old Feb 7, 2013 | 10:28 AM
BlwnAway's Avatar
BlwnAway
Yup, won't be long & the 200k+ club won't be that exclusive.
Old Feb 8, 2013 | 05:14 AM
ofioliti's Avatar
ofioliti
Congratulations! Sounds like you're still in love with the MINI. I would be hard pressed to find a car that I would enjoy as much as my MINI.
Old Feb 8, 2013 | 02:25 PM
rohhee's Avatar
rohhee
I hope my mini lasts that long!
Old Mar 24, 2013 | 02:33 PM
RGLARRY's Avatar
RGLARRY
Are you saying that you have not changed your thermostat or 2 stage cooling fan? Or is that considered normal and you did not list it?
chrisx18240
26
Mar 16, 2022 09:56 AM
mrjolliff
Oct 9, 2015 05:55 AM
Mini'mon
Aug 26, 2015 01:02 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
rphox2003
Aug 5, 2015 11:34 AM
