"Yellow" Engine Light on - code definition help please.
Old Feb 5, 2013 | 08:00 PM
mini coop's Avatar
mini coop
I had the engine light on my speedometer come on in "yellow". This is on a 2008 Mini Cooper base model.The garage retreived a code that said "Vanos exhaust actuator movement". The light has now turned itself off. Is there an explanation or definition to what this code means? The car drives and drove fine with no issues,but, I don't want anything serious to happen. Any help would be greatly appreciated.
Thank you in advance for the communities help.
Old Feb 16, 2013 | 05:59 PM
jlee924's Avatar
jlee924
How's your oil level? Vanos faults usually come up if you're low on oil
Old Feb 16, 2013 | 07:27 PM
mini coop's Avatar
mini coop
After reading other threads about this, it turns out to be a dirty solenoid and it also happens after a timing belt change which I had done in conjunction with a new water pump. Its ties into the belt tensioner.
Thanks for the suggestion. My oil was changed recently and checked out fine.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
