Navigation & Audio Mini Connected SA6NM Option, is an upgrade possible?
Old Feb 2, 2013 | 05:32 PM
FrozenMini's Avatar
FrozenMini
Just picked up my Mini last week, I was all excited to hook up my iPhone today and found out I have visual boost, not connected. According to the document this would be option SA6NM and could possibly be a software upgrade. Has anyone had this done?
My print out from the dealer even say 06FP Mini Connected, but it is not active for some reason.
Edit: Just figured out I have an oops car that got the display and what not.
Old Feb 4, 2013 | 11:29 AM
amancuso's Avatar
amancuso
Do you have NAV? it's impossible to have NAV without Connected.
Old Feb 4, 2013 | 11:41 AM
FrozenMini's Avatar
FrozenMini
No Nav. As I understand it I roughly have the uk visual boost option. I have an appointment with the dealer. They looked at my options and said I should have connect.
Old Feb 4, 2013 | 03:42 PM
rkw's Avatar
rkw
I guess you bought one of these: http://www.motoringfile.com/2010/09/...d-edition-car/
Old Feb 5, 2013 | 09:45 AM
cactusbob's Avatar
cactusbob
Mine was similar, all the stuff just not there. I used NCS Expert to add 6NM to the VO, then recoded the right modules. Mini Connected now works :-)
Old Feb 13, 2013 | 07:21 AM
FrozenMini's Avatar
FrozenMini
My car is at the dealer and they said something about changing the car's VO. So it looks like they are doing what you did.
Old Feb 13, 2013 | 07:46 AM
cactusbob's Avatar
cactusbob
Yes, that's exactly what I did. Mini here wanted to charge me £277 for a FSC code to activate it (not needed as the software on the car doesn't require it) as well as 3.5 hours of labour, so almost £600 or almost $950.
Old Feb 22, 2013 | 10:06 AM
FrozenMini's Avatar
FrozenMini
So the service adviser calls me and says my car is done, but due to this that MINI won't allow connected to be activated. Disappointed I go pick up my car and MINI connected is working just fine. Pandora and all. This is with an iPhone 5 using the short 30pin to lightning cable from Apple.
I did give the dealer a hint from someone off the forum about changing something in the Champ2 module. Maybe they did that. In any case it works now.
Old Feb 22, 2013 | 10:35 AM
cactusbob's Avatar
cactusbob
A good result
Old Feb 23, 2013 | 08:18 AM
FrozenMini's Avatar
FrozenMini
Dealer called me back and told me MINI did provide the code and wanted me to stop in to get it programmed. I told them it was working fine. They think what happened is the tech did one last programming before they gave the car to me and new code was programmed. If anyone has a similar car to mine, the dealer ordered the part for ~$300.
We are still negotiating who will be paying that, since they sold me the car with that option on the paperwork.
Old Feb 23, 2013 | 08:21 AM
cactusbob's Avatar
cactusbob
I think if the software version on your car is below a certain level then it doesn't require the FSC code. Since the option was on your paperwork then don't give them a penny :-)
Old Feb 27, 2013 | 03:37 AM
JimmyBlunt's Avatar
JimmyBlunt
Got my car last week and found out that i don't have mini connected either... even the dealer told me that all extras are included but i finally found out that i don't have the 6NM.
....even i have the 6NF, 6NE, 6FP and 6UM.
Is there any additional hardware required to enable the mini connected or is it just on software level.
If so what exactly needs to be enabled to get this working
Old Feb 27, 2013 | 05:38 AM
FrozenMini's Avatar
FrozenMini
It was just software for me. Part# the dealer ordered was 65-90-2-219-124. It took them a while to figure it out.
Old Feb 27, 2013 | 10:29 AM
cactusbob's Avatar
cactusbob
Just software, if you can code the car try adding 6NM to the VO and defaulting the CHAMP2 module :-)
Old Mar 4, 2013 | 03:45 AM
JimmyBlunt's Avatar
JimmyBlunt
I tried this but no success.
But the problem is that not only 6NM was missing but having the code $810 and $825 for australia and it restrictcs connected too! I removed this and set no country code and still not working.
I got it once that it said that no services are currently enabled..... But thats it :(
Old Mar 4, 2013 | 04:19 AM
cactusbob's Avatar
cactusbob
There is an option in CHAMP2 called something like A4A_Apps , set it to aktiv
Old Mar 4, 2013 | 04:26 AM
JimmyBlunt's Avatar
JimmyBlunt
i tried that and set it to active - no success! maybe if you could send me your entire CHAMP2 config so i have something to compare with that definitely works?
Old Mar 4, 2013 | 06:33 AM
cactusbob's Avatar
cactusbob
Here you go. There are two items that need to be changed: A4A and A4A_remote. You do have a combox and full bluetooth right?
Code:
HUD_M
	nicht_aktiv
TDA_CFG_HLC_DATA
	nicht_aktiv
TDA_CFG_VEHICLE_SER
	nicht_aktiv
TDA_CFG_IND_PDM_GR_NBR
	file0
TYP_LENKUNG
	rechtslenker
ZYLINDER_ZAHL
	4_zylinder
NANP_FORMAT
	nicht_aktiv
SVS
	aktiv
HDC_CIC
	nicht_aktiv
HIGH_BEAM_ASSISTANT
	nicht_aktiv
SYSTEM_GPS_RECEIVER
	aktiv
_PERSONALRADICDMMO
	nicht_aktiv
COMINGSTREET_KOMBI_HUD
	nicht_aktiv
ROTATION_WERTE_EINHEITEN
	nicht_aktiv
HUD_TURNSIGNAL
	nicht_aktiv
SERVICE_HISTORY
	nicht_aktiv
BASIS_KOMBI_MMI_LIST
	aktiv
DOORLOCKING_AFTER_DRIVING
	aktiv
NAVI_POI_ONLINE_SEARCH
	browser
SERVICE_MENUE
	aktiv
TVM_VARIANTEN
	kein_tvm
WELCOME_LIGHT
	nicht_aktiv
BMAP_JUNCTION_VIEW
	aktiv
CDMM_TV_FOLLOWING
	nicht_aktiv
CDMM_TV_AUTOSTORE
	nicht_aktiv
CDMM_TV_PRESETLIST
	nicht_aktiv
CDMM_TV_AUDIOTRACE
	nicht_aktiv
CDMM_TV_EPG
	nicht_aktiv
CDMM_TV_TELETEXT
	nicht_aktiv
HYBRID
	nicht_aktiv
OELSTANDSMENUE
	nicht_aktiv
M_KEY_SETTINGS
	nicht_aktiv
CIC_MDRIVE
	nicht_aktiv
CBS_VERSION_3_LOWER
	aktiv
MACRO_NIVI
	nicht_aktiv
NIGHTVISION_1
	nicht_aktiv
NIVI_2_OBJ_DETETECTION
	nicht_aktiv
ONBOARDCOMPUTER_DATE
	aktiv
SYSTEM_TTS
	aktiv
RSE_3
	kein_rse
CDMM_USB
	nicht_aktiv
CDMM_DVD_AOP_AUTOMATIC
	nicht_aktiv
LOGIC7_SYMBOL_C04
	nicht_aktiv
GYRO_INTERN
	aktiv
NAVI_FLEET_MODE
	nicht_aktiv
NAVI_MAPMODE_AUTOMATIC
	nicht_aktiv
OELSTAND_OENS
	nicht_aktiv
NAVI_USE_WHILE_UPDATE
	aktiv
NAVI_MAPSCROLL_LIGHTBEAM
	aktiv
NOTEPAD_CIC
	nicht_aktiv
KOMBI_AR_PRES
	nicht_aktiv
IBA
	nicht_aktiv
MACRO_FDS
	nicht_aktiv
FDS_POPUP_DEACTIVATE
	nicht_aktiv
CDMM_DVD_SINGLE
	nicht_aktiv
HUD_DISTANCE_INFO
	nicht_aktiv
FONDLOCK_POPUP_TIMESPAN
	nicht_aktiv
GETRIEBETYP_CIC
	nicht_aktiv
RSE_BRIGHTNESS
	nicht_aktiv
IPD_BEHANDLUNG
	nicht_aktiv
ROUTEN_ID_GUIDEDTOURS
	nicht_aktiv
ENABLE_BC2_AUTORESET
	aktiv
AUDIO_SYSTEM_VAR
	default
SL01_VIDEO
	nicht_aktiv
SL02_ES
	nicht_aktiv
SL03_IMPORT_EXPORT
	nicht_aktiv
SL04_PIA
	nicht_aktiv
SL05_KONTAKTE_EDIT
	nicht_aktiv
SL06_IBA_1
	aktiv
SL07_IBA_2
	aktiv
SL08_NUMMEREINGABE
	nicht_aktiv
SL09_BT_PAIRING
	nicht_aktiv
SL10_ASSIST_PANNENHILFE
	nicht_aktiv
SL11_BMW_ONLINE
	nicht_aktiv
SL12_BMW_INTERNET
	nicht_aktiv
SL13_ZIELEINGABE_SPELLER
	nicht_aktiv
SL14_ZIELEINGABE_KARTE
	nicht_aktiv
SL15_TRIPPLANER
	nicht_aktiv
SL16_NAVI_POI_SUCHE
	nicht_aktiv
SL20_RESERVE
	nicht_aktiv
SL21_IBA_3
	aktiv
MOMENTDISTRIBUTION_MENU
	nicht_aktiv
DSC_MENUE
	aktiv
DSC_OFF_CIC
	nicht_aktiv
SPRECHERWAHL1
	weiblich
HMI_FUER_DAB_DMB
	dab_dmb_radio
MMS
	standard
SPRECHERWAHL2
	weiblich
SPRECHERWAHL3
	weiblich
ETC
	nicht_aktiv
GUIDING_KOMBI_HUD
	rueko_mit_hud
NAVI_RNC_MAINMAP_TEXT
	permanent
TIMER_VOLLBILDKARTE
	permanent
DMB_MAX_FRAMERATE
	wert_0
MDRIVE_RUEKO
	nicht_aktiv
SCHNEEKETTENERKENNUNG
	nicht_aktiv
MACRO_PDC_TOPVIEW
	nicht_aktiv
MACRO_PMA
	nicht_aktiv
MACRO_L6_PARKMENU
	nicht_aktiv
SPEEDLIMIT_INFO
	nicht_aktiv
MULTICHANNEL_MMC_DVD
	nicht_aktiv
DVDAUDIO_AOP
	nicht_aktiv
DVDVIDEO_AOP
	nicht_aktiv
HVAC_AIRLAMINATION_DRV
	nicht_aktiv
HVAC_AIRLAMINATION_CODRV
	nicht_aktiv
HVAC_AUTOMATIC_INTENSITY
	nicht_aktiv
HVAC_POPUP_AIRDISTR
	nicht_aktiv
HVAC_CABRIO
	nicht_aktiv
HVAC_POPUP_AUTO_TOGGLE
	nicht_aktiv
HVAC_INDEPENDENT_AIR
	nicht_aktiv
HVAC_FOND_ACTIVATION
	nicht_aktiv
YC_AUX1
	reserved
RGB_YUV_AUX1
	reserved
RSE_INTERNAL_VIDEO_PLAYBK
	wert_255
AUX2_INTEGRATED_IN_RSE
	wert_255
AUX3_IN_RSE_RIGHT_SCREEN
	wert_255
AUX4
	standard
YC_AUX4
	reserved
ACC_SGN
	nicht_aktiv
ACC_CIC
	nicht_aktiv
DCC
	nicht_aktiv
FGR
	nicht_aktiv
RDC_SAFETY
	nicht_aktiv
HEADUP_DISPLAY
	nicht_aktiv
HUD_POSITION
	nicht_aktiv
DOORLOCKING_SEATMEMORY
	nicht_aktiv
BACKDOOR_OPENINGANGLE
	nicht_aktiv
BRAKE_ASSISTENT
	nicht_aktiv
SMG
	nicht_aktiv
DKG_CIC
	nicht_aktiv
EDC_CIC
	nicht_aktiv
MACRO_REARVIEW
	nicht_aktiv
MACRO_SIDEVIEW
	nicht_aktiv
ACTIVE_BACKREST_ADJ
	nicht_aktiv
HUD_ACTIVATION
	nicht_aktiv
LANE_CHANGE_WARNING
	nicht_aktiv
LANE_DEPARTURE_WARNING
	nicht_aktiv
DOOR_LOCKING_SELECTABLE
	aktiv
USB_AVAILABLE
	aktiv
HVAC_SEATVENTILATION_FRNT
	nicht_aktiv
HVAC_SEATVENTILATION_FOND
	nicht_aktiv
HVAC_SEATHEAT_DISTR_FRONT
	nicht_aktiv
HVAC_SEATHEAT_DISTR_FOND
	nicht_aktiv
HVAC_SEATCLIMATE_LED
	nicht_aktiv
HVAC_POPUP_SEATCLIMATE
	nicht_aktiv
MACRO_CAM_LEGALDISCLAIMER
	ld_mit_timeout
MACRO_NIVICAM_LDISCLAIMER
	ld_mit_timeout
FBM_ENT
	aktiv
FBM_NAVI
	aktiv
FBM_IBA
	aktiv
FBM_MENUJUMPS
	aktiv
FBM_OTHER
	aktiv
FBM_SHORT_INFO
	aktiv
FBM_DETAILED_INFO
	aktiv
VIDEO_WATCHDOG_SIDEVIEW
	aktiv
VIDEO_WATCHDOG_REARVIEW
	nicht_aktiv
VIDEO_WATCHDOG_TOPVIEW
	nicht_aktiv
HVAC_INDEPENDENT_HEATING
	nicht_aktiv
VIDEO_WATCHDOG_NIGHTVISIO
	nicht_aktiv
EARLY_VIDEO_LEGALDISCL
	kein_ld
MUTE_PIN_BEHAVIOUR
	no_function
MUTE_PIN_SOURCE
	no_source
FOLLOWING_AVAILABLE
	aktiv
FM_BAND_MW
	aktiv
EXCL_MULTICHANN_FRONT_DVD
	nicht_aktiv
EXCL_MULTICHANNL_REAR_DVD
	nicht_aktiv
EXCL_MULTICHANNEL_MMC
	nicht_aktiv
EXCL_MULTICHANNEL_TV
	nicht_aktiv
TI_CAT_DEFAULT_WEATHER
	aktiv
TI_CAT_VMAP_WEATHER
	aktiv
TI_CAT_VMAP_PARK_PUBL
	aktiv
TI_CAT_VMAP_ONROUTE
	nicht_aktiv
TI_CAT_DEFAULT_FORECAST
	aktiv
TI_CAT_DEFAULT_INCIDENTS
	aktiv
PHONE_RSE
	nicht_aktiv
TI_CAT_DEFAULT_ROADWORKS
	aktiv
TI_CAT_DEFAULT_CLOSED
	aktiv
TI_CAT_DEFAULT_PARK_PUBL
	aktiv
TI_CAT_DEFAULT_ONROUTE
	aktiv
TI_DAB_TMC
	nicht_aktiv
TI_TPEG
	nicht_aktiv
TI_DETOUR_BUTTON_DISABLED
	nicht_aktiv
TI_POPUPS_DISABLED
	nicht_aktiv
TI_USE_COMBI_DISABLED
	nicht_aktiv
TI_CAT_VMAP_FLOW
	nicht_aktiv
TI_CAT_VMAP_FORECAST
	aktiv
TI_CAT_VMAP_INCIDENTS
	aktiv
TI_CAT_VMAP_ROADWORKS
	aktiv
TI_CAT_VMAP_CLOSED
	aktiv
VOL_MAX_ON
	standard
PB_DOWNLOAD_PRIORITY
	wert_03
AUDIO_SIGNAL_ROUTING_CIC
	standard
TIME_DIST_SAME_PRIO_3
	standard
TIME_OUT_GONG_3
	standard
MULTICHANNEL_CIC
	nicht_aktiv
PAN_PROFILE
	nicht_aktiv
CDMM_BT_DATABASE
	nicht_aktiv
HDD_ACCESS_VIA_ETHERNET
	nicht_aktiv
MODELL_CIC
	mini
API_MTP_EIN_AUS_CIC
	aktiv
API_IPOD_EIN_AUS_CIC
	aktiv
EXTERNAL_CALL_LISTS
	aktiv
MICROPHONE_SENSITIVITY
	l4_mic
RINGTONE_CIC
	mini
INBAND_RINGING
	nicht_aktiv
SECURE_SIMPLE_PAIRING
	nicht_aktiv
ASSIST
	nicht_aktiv
ASSIST_INITIALIZATION
	nicht_aktiv
ASSIST_ECALL
	aktiv
ASSIST_BCALL
	aktiv
FBM_SELECTION
	two_buttons
ASSIST_SERVREQ
	aktiv
ASSIST_HOTLINE
	aktiv
ASSIST_AUTOMATIC_SERVREQ
	aktiv
ASSIST_AKD
	aktiv
ASSIST_MY_INFO
	aktiv
ASSIST_REMOTE_HVAC
	aktiv
ASSIST_REMOTE_HORNLIGHT
	nicht_aktiv
ASSIST_FCD
	aktiv
ASSIST_ECALL_CALL_HANGUP
	aktiv
ONLINE_BROWSER
	nicht_aktiv
STARTUP
	nicht_aktiv
ONLINE_SERVICES
	nicht_aktiv
ONLINE_SERVICES_GLS
	nicht_aktiv
TDA_ASC_STATUS_CIC
	nicht_aktiv
A2DP_PROFILE
	nicht_aktiv
AUX1
	wert_41
TDA_MSC_STATUS_CIC
	nicht_aktiv
TDA_TDC_STATUS_CIC
	nicht_aktiv
TDA_BDA_STATUS_CIC
	nicht_aktiv
TDA_HLC_STATUS_CIC
	nicht_aktiv
TDA_DEACTIVATE_STATUS_CIC
	aktiv
TDA_CFG_SER_ERR_SINK_CIC
	aktiv
GUIDING_TIMING_MLS
	dynamic
TDA_ATM_ACTIVE_CIC_0C
	nicht_aktiv
TDA_CFG_CUST_MOBILE_CIC
	aktiv
LCP_ECHO_REQUEST
	aktiv
INTERVAL_LCP_ECHO_REQUEST
	value_0
FEATURE_DISPLAY
	deviceid
TDA_ATM_START_TIME
	standard
TDA_ATM_INTERVAL
	standard
TDA_ATM_CALL_ID
	standard
TDA_CFG_LEVEL3
	aktiv
PIA_RESERVED
	nicht_aktiv
PIA_PORTIERUNGSMASTER
	aktiv
PIA_RUECKSETZEN_DEFAULT
	aktiv
GUIDING_TIMING_KM
	dynamic
KOPIEREN_VON_PROFILEN
	aktiv
PORTIERUNG
	aktiv
TEMPORAERER_PROFILWECHSEL
	aktiv
PERMANENTER_PROFILWECHSEL
	aktiv
L4_L6_KOMMUNIKATIONSSCHLT
	l4_aktiv
BEHANDLUNG_2S_TIMER
	aktiv
PIA_MMI
	kein_pia_menue
TEXTKUERZUNG
	aktiv
L6_ZBE_ARBITRATOR
	nicht_aktiv
ANTRIEB
	nicht_aktiv
IHKA_VARIANTE
	keine_ihka
SHUTDOWN_DELAY_TIMER_1
	wert_01
SHUTDOWN_DELAY_TIMER_2
	wert_01
EXTERNER_MOST
	aktiv
DUMPER_LEVEL
	nicht_aktiv
SPEECH_2_TEXT
	nicht_aktiv
EINHEITEN_MASTER
	pia_service
DEFAULT_SVS_DIALOG
	standard
NAVI_MYPOI_EXPORT
	nicht_aktiv
ALTERNATIV_ROUTEN
	aktiv
PRODUKTLINIE
	pl3
LANGUAGE_14
	nicht_aktiv
LANGUAGE_15
	nicht_aktiv
SLEEPDELAY_TIMERVALUE
	wert_00
LANGUAGE_16
	nicht_aktiv
AUDIO_REMOTE_CONTROL
	nicht_aktiv
KOMBI_CIC
	kombi_high
PDC_DIRECTION
	horizontal
HVAC_MSA_EFFICIENCY
	nicht_aktiv
GRACENOTES_ACCESS
	most
PIM_OVERVIEW
	aktiv
CLIMATE_ACT_ONE_TIMER
	nicht_aktiv
PIM_ADR_VALID
	nicht_aktiv
ASSIST_VEHICLEFINDER_SHOW
	nicht_aktiv
CONTACT_NUMBERS_BT
	aktiv
ASSIST_SVR_SHOW
	nicht_aktiv
TVC_WIDTH
	wert_580
BRAKE_ASSISTENT_3
	nicht_aktiv
SDARS_REPLAY_AUTOMATIC
	aktiv
BRAKE_ASSISTANT_FCW
	nicht_aktiv
TDA_TSR_INSTANCE_ID_C0D
	wert_00
CDMM_TV_BML
	nicht_aktiv
DISPLAY_VARIANTE
	schmales_display
HU_INTERNAL_VIDEO_PLAYBK
	wert_255
SDARS_IN_EXBOX
	inbox
NAVI_3D_MAP_OPTIONS
	nicht_aktiv
CDMM_CHANGER_3
	kein_cdc
JUNCTION_VIEW_HUD
	nicht_aktiv
CDMM_ES_ALBUM_INFO
	nicht_aktiv
GUIDED_TOURS
	nicht_aktiv
NAVI_KREUZUNGSZOOM
	aktiv
NAVI_DEST_IMPORT
	nicht_aktiv
NAVI_DEST_EXPORT
	nicht_aktiv
NAVI_ROUTE_RECORD
	nicht_aktiv
MAP_SCROLL_3D
	nicht_aktiv
AREA_CODE_DVD
	alle_anderen
TVC
	wert_255
RVC_CIC
	wert_255
NVC
	wert_255
RADIO_DAB_VARIANTEN
	single_tuner_single_hw
RUEKO_PU_0308
	nicht_aktiv
TI_VICS
	nicht_aktiv
RADIO_WEATHERBAND
	nicht_aktiv
MMC_CIC
	wert_255
TV
	wert_255
BT_DATA_SERVICE
	nicht_aktiv
ASSIST_REMOTE_DOORLOCK
	aktiv
ASSIST_AKD_SHOW_READ
	aktiv
ENTWICKLER_MENUE
	nicht_aktiv
ENTWICKLER_MENUE_ASIEN
	nicht_aktiv
FBM_DEFAULT
	aktiv
HEADLIGHT_SETTING
	aktiv
NAVI_ROAD_PREVIEW
	aktiv
NAVI_2D_MAP_OPTIONS
	nicht_aktiv
NAVI_TRIP_EXPORT
	nicht_aktiv
TELEX
	nicht_aktiv
DUN_PROFILE
	nicht_aktiv
NAVI_TRIP_IMPORT
	nicht_aktiv
NAVI_MYPOI_IMPORT_C0C
	nicht_aktiv
NAVI_SPLIT_GUIDINGPOPUP
	aktiv
CDMM_VIDEO
	nicht_aktiv
CDMM_ES
	nicht_aktiv
NAVI_MECCA_INDICATOR
	aktiv
LANGUAGE_UPDATE
	nicht_aktiv
NAVI_ROUTE_STUDY
	nicht_aktiv
KOMBIGUIDING_SCHALTBAR
	nicht_aktiv
HYBRID_EFFICIENCY_GRAPHIC
	nicht_aktiv
COMFORT_OPENING
	nicht_aktiv
SIDE_VIEW_CAMERA
	wert_255
MMC_VARIANTE
	wert_02
PU_0909
	aktiv
FM_BAND_LW
	nicht_aktiv
RADIO_AM_LW
	aktiv
TI_CA_TPEG_C0B
	nicht_aktiv
PIM_DRIVING_TEXT_LENGTH
	one_page
BRAKE_ASSISTANT_CCM
	nicht_aktiv
HUD_ROTATION
	nicht_aktiv
M_DIGITAL_TACHO_EINH
	nicht_aktiv
EXT_MUSIC_MANAGEMENT
	nicht_aktiv
TIME_LAG_IMG_CHAMP
	standard
TIME_LAG_IDG_CHAMP
	standard
RSE_SERVICE_MESSAGES
	nicht_aktiv
MDRIVE_CONFIG
	1_menu
M_DIGITAL_TACHO
	aktiv
VOL_MAX_ON_RSE
	standard_19h
MAX_VOL_STEP_RSE
	standard_39h
CDMM_USB_HMI
	new
SLEEPDELAY_CLAMP30B_MIN_2
	wert_ff
ENT_CHANNELBUFFER
	wert_11
ENT_ITEM_UPDATE_COUNT
	wert_1
ENT_QUERY_CHANNEL
	wert_50
ENT_MANAGED_CHANNEL
	wert_50
ENT_TEMPORARY_CHANNEL
	wert_100
ENT_MAX_NUMBER_FAVOURIES
	wert_100
ENT_ONLINE
	nicht_aktiv
ECO_ROUTE_TEXT
	nicht_aktiv
MMI_STATISTIK
	nicht_aktiv
SERVICE_HISTORY_WHO
	default
ENABLE_SW_INFO_REQUEST
	cic_high
COLOUR_SWITCH
	nicht_aktiv
HELLIGKEIT_AMBILIGHT
	nicht_aktiv
COLOUR_SWITCH_LINES
	nicht_aktiv
NAVI_POSITION_MENU
	aktiv
SECONDARY_HFP
	nicht_aktiv
ENT_VIDEO_VORNE_GESPERRT
	nicht_aktiv
DAB_STANDARD
	dab_plus
EMAIL_READ_OUT_BUTTON
	aktiv
PHONE_SMS_READ_OUT_BUTTON
	aktiv
SINGLE_OR_MULTILINK
	singlelink
DAYDRIVING_LIGHT
	standard
MACRO_TRAILER_COUPLING
	nicht_aktiv
CONNECTIVITY_SYSTEM_VER
	ecu_sw_vid
PHONEBOOK_NAME_DIS_ORD_1
	firstname_lastname
POI_DETAILS
	nicht_aktiv
SPEEDLOCK_FREISCHALTMENU
	nicht_aktiv
VERBRAUCH_CIC
	mpg_uk
NAVI_VARIANTE
	ece
NAVI_SHOW_GEOCORDINATES
	aktiv
NAVI_TRAFFIC_INFO_MAP
	aktiv
ACOUSTICAL_LOCK_CONFIRM
	nicht_aktiv
VIDEO_NUR_MIT_HANDBREMSE
	aktiv
LANGUAGE_1_3
	deutsch
LANGUAGE_2_3
	english_uk
LANGUAGE_3_3
	spanisch
LANGUAGE_4
	franzoesisch
LANGUAGE_5
	italienisch
LANGUAGE_6
	nicht_aktiv
LANGUAGE_7
	niederlaendisch
LANGUAGE_8
	polnisch
LANGUAGE_9
	portugiesisch
LANGUAGE_10
	russisch
LANGUAGE_11
	schwedisch
LANGUAGE_12
	tuerkisch
LANGUAGE_13
	griechisch
LANGUAGE_MASTER
	english_uk
NAVI_FUELSTOP_PROPOSAL
	aktiv
NAVI_PFEILANSICHT
	aktiv
SL17_ASIA_NAVI_POI
	nicht_aktiv
SL18_ASIA_SEARCH
	nicht_aktiv
SL19_ASIA_SETTINGS
	nicht_aktiv
AVOID_VIGNETTE
	aktiv
ECALL_INSTANCE_ID
	wert_01
SOFTWARE_UPDATE_MANAGER
	aktiv
CDMM_USB_VIDEO
	first_usb
A4A
	aktiv
AUDIO_OFFSET
	aktiv
CDMM_USB_POD_BOOK
	aktiv
TYPE_OF_FUEL
	alle_kraftstoffe
EINHEITEN_WEGSTRECKE_3
	mls_yrd
GUIDING_TIMING
	ece
MACRO_PDC
	nicht_aktiv
RDC
	nicht_aktiv
RPA_CIC
	aktiv
DWA
	aktiv
PDC_SENSOR_HINTEN
	kein_sensor
PDC_SENSOR_VORN
	kein_sensor
LEGAL_DISCLAIMER_TIME
	kein_ld
AUDIO_SYSTEM_CIC
	stereo
RADIO_COUNTRY
	ece
RADIO_SDARS
	nicht_aktiv
AF_FUNKTION
	af_ein
RADIO_IBOC
	nicht_aktiv
ONLINE_CONFIG_TABLE_INDEX
	config_table_0
ONLINE_DAR_INDEX_03
	dar_6
RADIO_DAB
	aktiv
DAB_LAENDERVARIANTEN
	ece
CHECKBOX_TP
	aktiv
DAB_BAND
	beide
TI_TMC
	aktiv
TI_CA_TMC
	nicht_aktiv
TI_TMC_REGIONAL
	nicht_aktiv
TI_FALLBACK_DISABLED
	nicht_aktiv
PHONE_TYPE_C0B
	combox
PHONE_SMS
	aktiv
VCARD_OVER_MOST_CIC
	aktiv
PHONE_ALL_INC_CALLS_LIST
	aktiv
CDMM_USB_AUDIO_DOUBLE
	aktiv
MICROPHONE_0A
	no_microphone
MIC_OVER_MOST
	aktiv
PHONE_OBJPUSH_MENUE
	nicht_aktiv
ADRESSBOOK
	aktiv
CDMM_USB_AUDIO_AZ_SEARCH
	aktiv
CDMM_USB_COMPOSER_IPOD
	enabled
API_TYPE
	combox
MESSAGE_FILTER
	aktiv
PHONE_RESPONSE_HOLD
	nicht_aktiv
PICTURE_ALBUM_ARTS
	aktiv
BT_MODUL_ON_OFF
	nicht_aktiv
AUDIO_PLAYER_ON_OFF
	nicht_aktiv
MUTE_BUTTON
	aktiv
CDMM_BLUETOOTH_AUDIO
	aktiv
CDMM_USB_COVER_ART
	aktiv
FUNCTIONALITY_VIEWER
	aktiv
DATACOM_INTERFACE
	combox
DATACOM_TRANSFER
	mamac
CONTACT_NUMBERS_BCALL
	aktiv
GPS_FROM_NAVI
	aktiv
ASSIST_VI_PLUS
	aktiv
BAUART_CIC
	limousine
COUNTRY
	ece
CONTACT_NUMBERS_DEALER
	aktiv
ONE_SHOT_DEST_INPUT_C0D
	nicht_aktiv
NAVI_MAP_ARROWVIEW
	aktiv
NAVI_FULL_GUIDINGPOPUP
	aktiv
SPEEDLOCK_X_KMH_MIN
	nicht_aktiv
SPEEDLOCK_X_KMH_MAX
	nicht_aktiv
FM_DEEMPHASIS
	wert_01
FM_BAND_KW
	aktiv
TI_CAT_DEFAULT_FLOW
	aktiv
TI_VINFO
	aktiv
PHONE_MPC
	aktiv
BT_PHONE_INSTANCE_ID
	wert_02
PIM_CROSS_USE
	aktiv
MACRO_PIM
	aktiv
PIM_TTS
	aktiv
TELEMATIC_INSTANCE_ID
	instanceid_0x01
CONTACT_NUMBERS_HOTLINE
	aktiv
NAD_PHONE_INSTANCE_ID
	wert_01
TDA_CFG_AUTO_TRIG_CIC_0C
	nicht_aktiv
NAVI_INFO_INSTANCE_ID
	wert_01
SOFTWARE_UPDATE_ASSISTANT
	aktiv
BAUREIHE_CIC
	r56
DEFAULT_WEG_EINHEIT
	mls
DEFAULT_DRUCK_EINHEIT
	psi
DEFAULT_TEMPERATUR
	celcius
DEFAULT_DATUM
	mm_dd_yyyy
DEFAULT_ZEIT_EINHEIT
	12h
EINSTELLUNG_MEILEN
	mls_uk
EXTERNE_MOST_DIAG
	aktiv
PHONEBOOK_NAME_ORD
	aktiv
REMOTE_HMI
	aktiv
TERMINAL_UI
	nicht_aktiv
MODE_HARDKEY
	radio_cd
FOLLOWING_DAB_FM
	aktiv
DAB_DABFOLLOWING
	aktiv
DAB_FOLLOWING_CHECKB_HMI
	aktiv
ANZEIGE_FREQ
	nicht_aktiv
A4A_REMOTE_APPS
	aktiv
FBM_TEL
	aktiv
PHONE_CONFERENCE_CALL
	aktiv
CDMM_USB_AUDIO_SINGLE
	aktiv
CDMM_USB_COMPOSER_MTP
	enabled
CDMM_AUX_HU
	nicht_aktiv
Old Mar 4, 2013 | 08:35 AM
JimmyBlunt's Avatar
JimmyBlunt
Thanks for that mate!
'.... but still no success: The 2 A4A settings were correct and automatically activated by defaulting the CHAMP2 module.
I definitely have the Combo-Box an the Bluethoth extension:
Here are the main options 6NF/6ND/6VC/6NE/6FP/6UM/
And these are the differences ....
Code:
   YOUR_SETTING 		 MY_SETTING
_PERSONALRADICDMMO		CDMM_PERSONALRADIO
ONLINE_BROWSER
	nicht_aktiv
	wert_00
NAVI_KREUZUNGSZOOM
	aktiv			nicht_aktiv
	aktiv			nicht_aktiv
HEADLIGHT_SETTING
	aktiv			nicht_aktiv
NAVI_ROAD_PREVIEW
	aktiv			nicht_aktiv
SIDE_VIEW_CAMERA
	wert_255
	cic_high
	wert_ff			wert_90
SECONDARY_HFP
	nicht_aktiv		aktiv
DAB_STANDARD
	dab_plus		nicht_aktiv
	nicht_aktiv		aktiv
MACRO_PDC\
	nicht_aktiv		aktiv
AUDIO_SYSTEM_CIC
	stereo			hifi
SPEEDLOCK_X_KMH_MIN
	nicht_aktiv		3_kmh
SPEEDLOCK_X_KMH_MAX
	nicht_aktiv		3_kmh
TI_VINFO
	aktiv
TERMINAL_UI
	nicht_aktiv		aktiv
MODE_HARDKEY
	radio_cd		more_sources
And the following parameters and values are completely missing in yours.
Maybe there is something not right??
Code:
CONFIG_INDEX
	config_index_3
DPAS_INDEX
	dpas_3
BRAKE_ASSISTANT_CONF
	nicht_aktiv
DATUMSFORMAT_AR_ASIA
	nicht_aktiv
ENABLE_SW_INFO_REQUEST_14
	nicht_aktiv
FBM_NO_TOUCHSENSOR
	nicht_aktiv
ONLINE_BROWSER_C0D
	nicht_aktiv
SIDE_VIEW_CAMERA_0A
	wert_255
DAB_BAND_CHAMP
	beide
BEV
	nicht_aktiv
CONNECTED_DRIVE
	nicht_aktiv
ECO_FDS_POPUP
	nicht_aktiv
ECO_LIMIT
	nicht_aktiv
ECO_MODE
	nicht_aktiv
ECO_MODE_CONF
	nicht_aktiv
ECO_ROUTE
	nicht_aktiv
ECO_TIPPS
	aktiv
EFF_DYN_FORECAST_HYB
	na
EFF_DYN_SPORT_CID
	nicht_aktiv
EFF_DYN_SPORT_UNIT
	nicht_aktiv
EFF_DYN_SYS_CID
	nicht_aktiv
FDS_NAMING_MODE
	bis_0711
HIGH_END_AUDIO_MENUE
	kein_menue
HIST_BEV_CONSUMP
	nicht_aktiv
HIST_BEV_CONSUMP_SCALE_1
	50
HIST_BEV_CONSUMP_SCALE_2
HIST_BEV_CONSUMP_SCALE_3
HIST_BEV_RECUP_SCALE_1
	20
HIST_BEV_RECUP_SCALE_2
	20
HIST_BEV_RECUP_SCALE_3
	30
HIST_CONSUMP_AVERAGE
	kein_wert
HIST_FDS_MODE_COLOR
	nicht_aktiv
HIST_FDS_MODE_NAME
	nicht_aktiv
HIST_GAS_CONSUMP
	nicht_aktiv
HIST_GAS_CONSUMP_SCALE_1
	20
HIST_GAS_CONSUMP_SCALE_2
	80
HIST_GAS_CONSUMP_SCALE_3
	60
HIST_GAS_CONSUMP_SCALE_4
	40
HIST_HYB_CONSUMP
	nicht_aktiv
HIST_HYB_CONSUMP_SCALE_1
	20
HIST_HYB_CONSUMP_SCALE_2
	20
HIST_HYB_CONSUMP_SCALE_3
	30
HIST_HYB_CONSUMP_SWITCH
	nicht_aktiv
HIST_ZOOM
	nicht_aktiv
MAXGLOBALREMOTECOMMANDS
	v20
MAXLOCALREMOTECOMMANDS
	v0
PHONEBOOK_CACHING
	aktiv
RR_SPEZ_KLZ
	nicht_aktiv
SLEEPDELAY_TIMERVALUE_2
	wert_1e
TI_VINFO_C0B
	aktiv
ENT_HUDRIVE_INSTALLED
	aktiv
EXTENDED_CC_MESSAGES
	aktiv
ONLINE_BROWSER_LIVE
	nicht_aktiv
SETTINGS_DOORLOCKING
	aktiv
SETTINGS_HOMELIGHT_PERIOD
	aktiv
SETTINGS_INFO_DISPLAY
	nicht_aktiv
SETTINGS_LIMIT
	aktiv
SETTINGS_SPIRITOFECSTASY
	nicht_aktiv
SETTINGS_TIP_BLINKING
	aktiv
SETTINGS_TOURIST_LIGHT
	nicht_aktiv
SETTINGS_TRACTION
	aktiv
TDA_CFG_BDA_REMOTE_HELP
	aktiv
TPEG_TAP
	nicht_aktiv
TRAVEL_BC
	aktiv
DEBOUNCE_KOMBI_BASIS
	defaultwert_50
FAS_INSZENIERUNG
	nicht_aktiv
GEZIELTES_ANLEUCHTEN
	nicht_aktiv
PERSONEN_WARNUNG
	nicht_aktiv
VOICE_LANGUAGE_RR_US
	nicht_aktiv
HIST_Y_SCALE_STEP_1
	000
HIST_Y_SCALE_STEP_2
	000
HIST_Y_SCALE_STEP_3
	000
HIST_Y_SCALE_STEP_4
	000
HIST_Y_SCALE_STEP_5
	000
HIST_Y_SCALE_STEP_6
	000
SWT_ARABIC
	nicht_aktiv
ZBE_LOW
	nicht_aktiv
EFF_DYN_SAILING
	nicht_aktiv
ASD_CIC
	ls_diag_on
A4A_LEGAL_DISCLAIMER
	nicht_aktiv
CBS_MOBIGUAR_LIFELONG
	nicht_aktiv
DAC
	none
	dac_ccm
	dac_popup
GATEWAYTABLE
	l6_mue
TIMESTAMP_DISPLAY
	nicht_aktiv
VANITY_DIALLING_EIN_AUS
	aktiv
A4A_PROD_MONTH
	nov
A4A_PROD_YEAR
	2012
HFP_AUDIO_PROFILE
	profile_1
MSA_VOLUME_CONTROL
	nicht_aktiv
TERMINAL_UI_LINK
	aktiv
TERMINAL_UI_PORT
	kuzu
Old Mar 4, 2013 | 08:53 AM
cactusbob's Avatar
cactusbob
Quite possibly you have a much later version of software on your headunit and your car. Can you post your MEDIA contents? When you changed your VO, did you code it to both CAS and FRM?
Old Mar 4, 2013 | 10:27 AM
CrazyRaymond's Avatar
CrazyRaymond
Wow! I'm excited.
Cactusbob, how many modules do you have to add the VO to?
CAS, FRM, and CHAMP2... Any more before i try?
JimmyBlunt, my CHAMP2 config looks similar to yours, any success by now?
Old Mar 4, 2013 | 10:33 AM
cactusbob's Avatar
cactusbob
Just followed the instructions from the web somewhere, the VO just needs adding to CAS and FRM. CHAMP2 gets defaulted which then sets it up according to the VO and the info in the Datens. I coded MEDIA too, but I don't think that was necessary. Just setting A4A and A4A_REMOTE_APPS to aktiv did the job though.
Old Mar 4, 2013 | 11:07 PM
JimmyBlunt's Avatar
JimmyBlunt
Hi cactusbob
i coded both the CAS and FRM ( so first code and the write) for both of them.
Spoke to my dealer today and he confirmed that I definitely have all what is required for mini-connected but that it's just not enabled - And Mini can't do this due to this stupid laws here.
But he mentioned that it might be just a code or something to put in - but he wasn't sure ...I just wonder what this code might do??
The only thing i found out today as that if i enable the developer menu and browser i get to the menu i the screenshots were it says to update connected ? But how?
and here attached my MEDIA ( using CMEDIAR.C05)
Code:
TYP_LENKUNG
	rechtslenker
BT_EIN_AUS_MED
	aktiv
SPRACHE
	englisch
	koreanisch
	china_trad
	russisch
BT_UFN
	wert_02
BT_OBJECT_PUSH
	nicht_aktiv
PHONE_TYPE_JAPAN
	nicht_aktiv
	wert_03
	l4_mic
INBAND_RINGING
	nicht_aktiv
API_TWO_USB_M
	aktiv
SWUP_ENABLE_SW_UPDATES
	aktiv
SWUP_SOURCE_USBMSCDD
	aktiv
A2DP_AVRCP_EIN_AUS
	aktiv
UNICODE_EIN_AUS
	nicht_aktiv
SORTING_VARIANT_M
	standard
AUDIO_SOURCE_FILE
	file_1
USED_MICROPHONES
	wert_01
MAIN_BOARD_ALONE
	mainboard_alone
RSE_HIGH
	nicht_aktiv
POWER_FOLLOW_UP_THRESHOLD
	wert_01
RINGTONE
	ringtone_1
USB_HUB_M
	nicht_aktiv
MULTI_PARTY_CALL_M
	aktiv
INCOMING_CALL_LIST_M
	aktiv
ETHERNET
	nicht_aktiv
DRM_CHIP_ENABLED
	aktiv
SECURE_SIMPLE_PAIRING_M
	nicht_aktiv
AUDIO_VERSTAERKER
	wert_01
COVER_ART_TWO_WIRE
	nicht_aktiv
MMS_EIN_AUS
	nicht_aktiv
SWUP_ENABLE_ENG_UPDATES
	nicht_aktiv
SWUP_ASK_CONF_ENABLED
	aktiv
CAR_TYPE_IPOD_LOGO
	mini
SWUP_SOURCE_ONLINE
	nicht_aktiv
RDU_CONTROL_ENABLED
	aktiv
SVR_ENABLED
	aktiv
OFFSET_BTAS
	wert_00
HEATING_CONTROL_ENABLED
	aktiv
VENTILATION_CNTRL_ENABLED
	aktiv
LIGHT_CONTROL_ENABLED
	nicht_aktiv
HORN_CONTROL_ENABLED
	nicht_aktiv
MY_INFO_SUPPORTED_POIS
	wert_25
TDA_CFG_IND_PDM_GR_NBR_M
	file0
TDA_CFG_TSM_TRIGGER
	all
PAN_PROFILE_M
	nicht_aktiv
TESTCALL_FLAG_ENABLE
	nicht_aktiv
STARTUP_ACTIVE
	nicht_aktiv
CONTACT_NUMBERS_BCALL_M
	nicht_aktiv
HEAD_BOOT_UP_TIMEOUT
	wert_15
M_SECURITY_MODE_ASH
	des_cbc_mac
M_SECURITY_MODE_AEH
	des_cbc
M_SECURITY_MODE_ASP
	hmac_sha_256
M_SECURITY_MODE_AEP
	aes_128
CONTACT_NUMBERS_DEALER_M
	nicht_aktiv
CONTACT_NUMBERS_HOTLINE_M
	nicht_aktiv
AUDIO_NOTES_EIN_AUS
	nicht_aktiv
IP_ROUTER
	aktiv
ONLINE_ROUTER
	aktiv
AKD_SUPPORTED_POIS
	wert_25
OFFSET_IPOD_SERIAL
	wert_00
TELEMATIK_VIN
	most_vin
RDL_CONTROL
	aktiv
API_IPOD_TWO_WIRE_SERIEL
	aktiv
API_IPOD_ONE_WIRE
	aktiv
FOLLOW_UP_TIME_EXTENSION
	wert_02
SWUP_CYCLIC_RST_THRESHOLD
	wert_05
SWUP_CYCLIC_RESET_TIMEOUT
	wert_255
SWUP_CYCLIC_MONITORING
	wert_20
DUN_PROFILE_M
	nicht_aktiv
TELEX_M
	nicht_aktiv
TDA_DEACTIVATE_STATUS_M
	aktiv
TDA_TSM_ACTIVE
	nicht_aktiv
TDA_FBLOCK
	nicht_aktiv
DATACOMM_CSIM
	nicht_aktiv
HEAD_UNIT_MODEL
	champ2_rueko
DATACOMM_INTERFACE
	nicht_aktiv
VIDEO_PLAYER_EIN_AUS
	aktiv
API_EIN_AUS_MED
	aktiv
GPS_POSITION_TIMEOUT
	wert_01
TDA_CFG_CUST_MOBILE_USE_M
	aktiv
CONFIG_INDEX
	config_index_3
TELEMATIC_COUNTRY_VARIANT
	row
GPS_FROM_MOST
	aktiv
EXTERNAL_CALL_LISTS_M
	aktiv
PICTURE_VIEWER_EIN_AUS
	aktiv
SIM_ENABLED_MB
	enabled_all
AVRCP_BROWSING_EIN_AUS
	nicht_aktiv
HANDSFREE_SECONDARY
	aktiv
VCARD_OVER_MOST_M
	aktiv
CONTACTS_EIN_AUS
	aktiv
FBLOCK_PHONEBOOK_EIN_AUS
	nicht_aktiv
DPAS_INDEX
	dpas_3
SMS_EIN_AUS_MED
	aktiv
CALENDAR_EIN_AUS
	aktiv
TEXT_NOTES_EIN_AUS
	aktiv
REMINDER_EIN_AUS
	aktiv
TASK_EIN_AUS
	aktiv
PIM_BILDER_EIN_AUS
	aktiv
REMINDER_TRIGGERS_EIN_AUS
	aktiv
EMAIL_EIN_AUS
	aktiv
PHONEBOOK_NAME_DISP_ORD_M
	last_first
MED_SVS_EIN_AUS
	nicht_aktiv
RESPONSE_ON_HOLD_M
	nicht_aktiv
BMW_INFO_SUPPORTED_POIS
	wert_25
SWUP_INSTALL_TIME_SWIP
	nicht_aktiv
USB1_IPOD_AUDIO
	analog
USB2_IPOD_AUDIO
	digital
Attached Thumbnails Mini Connected SA6NM Option, is an upgrade possible?-service-menu.jpg   Mini Connected SA6NM Option, is an upgrade possible?-noservice.jpg
Old Mar 4, 2013 | 11:38 PM
DiabloZoe's Avatar
DiabloZoe
So is this a part you need to already have in the vehicle? If you have the Bluetooth set up do you need anything else? Or can this just be coded?
Old Mar 5, 2013 | 07:45 AM
CrazyRaymond
JimmyBlunt, i will try this weekend and let you know. Not sure how to use the update, perhaps the official link here can help you out. http://www.mini.com/connectivity/sof...ate/intro.html
cactusbob, which Daten file are you using? Also, i'm wondering if there is a way you could share the string of VO that you have on your car, maybe JimmyBlunt and myself might be missing some VO that we were suppose to have to make it work?
