wheel spacer question
Old Feb 2, 2013 | 02:44 AM
JCWKART's Avatar
JCWKART
i was wondering what's the thickest wheel spacers that could be used with stock lug nut?
Old Feb 2, 2013 | 08:53 PM
kukaepe's Avatar
kukaepe
I think the real issue is how thick of a spacer can you install before you disturb the "hub centric" centering of the wheel. The better wheel spacers add a hub centric ring once the spacers become thick enough to be machined with an additional ring. I think that thickness is about 12mm. By that time you need to have longer bolts. Some places sell spacers with the appropriate longer lug bolts see...http://www.promini.com/product-exec/...arch_model/100
Old Feb 2, 2013 | 11:48 PM
Sacred Disorder's Avatar
Sacred Disorder
Another option is to go to a stud kit. If you plan on doing a lot of work to the car or changing tires for summer/winter or track tires it is definitely worth it. It will also allow you to run just about any spacer setup you want without issue.
Old Feb 3, 2013 | 10:47 AM
Creeve's Avatar
Creeve
I think 5mm is the thickest with the stock lugs. Most of the Mini specific spacers available thicker then that come with new lugs included.
Old Feb 4, 2013 | 12:58 PM
martinb's Avatar
martinb
My car (bought used) came with 15mm spacers and longer bolts.
Old Feb 4, 2013 | 12:59 PM
martinb's Avatar
martinb
Plus, they look cool in a Ricky Racer kind of way.
G1HQ
Dec 7, 2015 02:23 PM
Mini'mon
Aug 16, 2015 04:15 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
ki7hy
Aug 12, 2015 07:07 PM
ti22fjc
Aug 9, 2015 05:49 PM
