R56 Turbo??
Old Jan 30, 2013 | 04:52 PM
r56mini2008s's Avatar
r56mini2008s
Turbo??
I have a 2008 mini cooper s with turbo and was wondering if it has a BOV??
Old Jan 30, 2013 | 07:31 PM
Melangell's Avatar
Melangell
Same will say so and in conversation it is oft referred as such, but it's actually a diverter valve, not blowing off to atmosphere.
Questions?
Old Jan 31, 2013 | 09:43 AM
richardsperry's Avatar
richardsperry
The actual answer is yes. Both a diverter, or a blow off valve both accomplish the same purpose, but in different ways.
What happens when you are charging along, under full boost, and you jump off the throttle?
The turbo is still trying to pack in air. It is a pump spinning at 100,000+ rpm after all. Well if you don't do something, that pressure will back up and try to stall the compressor. So you open a valve and either dump the pressure to atmosphere, (not the best solution... but it does sound cool.) or you can direct the pressure to the intake side of the turbo.
NYMADMINI
Dec 14, 2016 02:33 PM
GAT
Oct 4, 2015 07:27 PM
Oct 1, 2015 12:13 PM
M7Speed
Oct 1, 2015 07:05 AM
EVMini
Sep 28, 2015 10:20 AM
