Navigation & Audio Upgrade Hi-Fi Premium Amp to Harman Kardon Amp
I have the 2009 MCS Hardtop with the HIFI Premium 10-Speaker System (Non-H/K).
I've read that my premium amplifier only has 230 watts, while the 2010-2013 H/K amplifier has 480 watts.
Can I buy the H/K amplifier online and swap it out for my non-H/K amp? I'm trying to drive some Infinity Reference (2 ohm) speakers I bought to replace the 6 front speakers (tweeters, mids, and woofers) and they are a bit power hungry, so more power with the same wiring harness would be great.
Please correct me if my information is wrong.
theSamuel, did you ever get an answer to this question? If not, did you decide on a different amp? I have the exact same set of Infinity reference speakers for my 2009 JCW with the 10 speaker HK upgrade. I have just installed the speakers and haven't done anything with the power supply. I agree they are very power hungry and I've noticed that the volume will max out pretty low when using the iPod adapter. I am shopping around for good amp options as well, so maybe we can compare notes? best, Mike
Wow! thats really great! So do you have an idea about how much additional power per channel is running to the speakers? This sounds like the easiest and most straightforward solution without having to tear the entire car apart to install a set of new amps. Did you install yourself or just have a dealer do it for you? Thanks! Mike
Gotcha. Do you have a link to the NAM thread your talking about? Re: door rattling, I fixed that by tearing the doors apart and dynamatting the hell out of them. I can help walk you through door panel removal if you need help. The inner panel is a pain in the A$$. I dynamatted the entire door skin, as well as the inner and outer door trim panels. It makes a huge difference. I suggest buying the dynamat extreme kit online. You get 10 sheets for like $130 or so.
TheSamuel, just wanted to let you know I've purchased a 2011 amp like you did to power my full set of Infinity Reference speakers in my 2009 JCW. Waiting for it to arrive next week. Do you happen to have the link to the thread you were talking about for getting it programmed? I'll need to work on that next. Did you end up dynamating your doors? Let me know if you have any questions, the panels are a pain to remove but the sound difference is worth the trouble. Thanks for your help! Mike
molala
Oct 2, 2015 01:53 PM
