R56 TPMS Funky in cold weather
Old Jan 26, 2013 | 02:43 PM
mbwicz's Avatar
mbwicz
I have a set of winter wheels, and put new tires on them this season. Both last year and this year, I get an 'inactive' warning every week or two once the weather gets below freezing. It usually resets once the temp goes up, or I reset the system. When I swapped the tires on in November, there were no issues until the temp got into the 20's.
My thought is either a sensor/tire has some moisture in it, or a sensor is on its way out.
Is there any way to find out which sensor(s) are giving the system a problem?
Thanks,
Mike
Old Jan 27, 2013 | 12:41 AM
MNIPWR's Avatar
MNIPWR
LOL! Sorry, I really did just laugh out loud. Since this seems like a serious question I will give you a serious answer. Pressure is directly related to temperature as long as the volume is constant. Since the volume inside the tire never changes, colder temperature=less pressure. So you don't need to worry, it's normal.
Old Jan 27, 2013 | 02:53 AM
ViperNL's Avatar
ViperNL
Not true, a tire looses about 1 psi a month due to air leakage. Plus every drop of 10F will make your tire pressure go down 1 psi, and increase if it gets warmer. If the weather gets colder, you need to add air to your tire. If it is getting warmer, you will need to take some out.
When measuring tire pressure, always measure cold tires, never when you've driven on them at basically anything over a mile or so, because the tires will heat up and the pressure will increase. This is calculated in when designing the tire, so nothing to worry about.
Old Jan 27, 2013 | 03:20 AM
mbwicz's Avatar
mbwicz
Tire pressure is still at 38 psi when I get the issue. It is not a 'low pressure' warning (I have seen this), it is an 'Inactive' warning.
Mike
Old Jan 27, 2013 | 09:56 AM
MNIPWR's Avatar
MNIPWR
The scientific law isn't true... interesting. Nice going, saying the same thing I did after saying that it wasn't true.
Mike
In that case, I wouldn't know.
Old Jan 27, 2013 | 10:48 AM
ZippyNH's Avatar
ZippyNH
Mike
I am wondering if the batteries are weak, and the cold makes the sensors stop working,,then they warm up a bit, and work?
Did the sensors get "serviced"when the snows were installed...really just an overpriced battery replacement....sometimes a valve core too.
Old Jan 27, 2013 | 11:00 AM
bmwr606's Avatar
bmwr606
+1 Zippy
my local tire store says the battery life is 5-7 years
the OP has a 2008 model ... so he is in the timeframe of end of life of the batteries
when i got my second set of wheels for winters, i ordered a second set of TPMS senders for them from tirerack
the batteries are potted in with a translucent material so i could see the batteries, they look like the coin shaped mercury batteries
the cold weather may cause weak battery voltage to drop further resulting in the "inactive" warning
scott
Old Jan 27, 2013 | 11:03 AM
mbwicz's Avatar
mbwicz
That makes sense, I never thought that they would have replaceable batteries. I will check it out.
Mike
Old Jan 27, 2013 | 11:09 AM
cnolan
I believe the BMW scan tools should indicate which is going out. My suspicion is a bad sensor. However, general rule of thumb is if the sensors are 4+ years old to just replace them all since there is a good chance the others may not be far behind.
ryGuyMCS
Oct 6, 2015 12:04 PM
Vaderm34
Sep 27, 2015 09:25 PM
shorenetworks
Sep 20, 2015 08:46 AM
Dedit Deus
Sep 17, 2015 06:11 AM
atlantaorange
Sep 16, 2015 12:43 PM
