HELP! How loose is my Cam Chain, see pic:
Old Jan 26, 2013 | 11:38 AM
bradyb's Avatar
bradyb
Here is a pic of my cam chain. For someone who knows, does this look right?
I'm right in the middle of installing a new valve cover gasket, cleaning out my intercooler pipes, and blasting the intake ports with some walnut action.
Before I head over to the dealer to get the gasket, I'm wondering if I should get the longer chain tensioner.
Thank you.
Old Jan 26, 2013 | 11:42 AM
Cheerio44's Avatar
Cheerio44
There's no picture...
Old Jan 26, 2013 | 12:38 PM
bradyb's Avatar
bradyb
Sorry the pic didn't load. There was aproximately 5/8 of play on the chain between the two cam gears. Should the chain be tight and straight between the two cam gears?
thank you
Old Jan 27, 2013 | 05:47 AM
alexs3d2's Avatar
alexs3d2
It can't be absolutely straight because there is a sliding rail between the gears... It should rest on the rail but not very tightly as that would cause wear on the rails. Also keep in mind that the chain is not loaded when the engine is not running neither is the tensioner fully extended (no oil pressure).
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
mikes603
Oct 5, 2015 12:12 PM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
donniedarko
Sep 29, 2015 01:16 PM
Nicefeet
Sep 24, 2015 06:53 PM
