D Stock Tire Pressures for Kumho Ecsta V700
Brian, Anyone,
What would you suggest as starting tire pressure for the Kumho Ecsta V700? I ran the Test and Tune at Fed Ex at 40 front/36 rear, and it felt OK, but I have no point of reference on these tires, so I thought I'd ask.
Suspension stock.
Any advice welcomed. Thanks,
Jim
Suspension stock.
Jim
Jim -
Assuming outside air temp of 70 degrees or more I would start the fronts at 40 cold and start the rears at 32. Depending on the track temp the fronts should heat up about 5-8 psi and the rears 3-5 psi. Adjust fronts to keep them at 45-50 and rears to keep a 7-10 psi differential depending on how you like the rotation. More differential = More rotation.
I'll make it easier for you and we'll do it the right way by using a pyrometer on the 18th. Just make sure you bug me about it, or I'll forget.
We'll determine the pressures then using BlueMCS's suggestions to start.
I've never actually run Ecstas on my own car, so I never kept up with the pressure requirements.
Brian
Brian
Well, I started with 42/35. Brian helped me out with the pyrometer, and it seemed the fronts needed a couple more pounds. So I added two pounds. This was a little better, but the tires still felt a bit greasy. Next time I think I'll try 47/41 or something like that.
Mainly, I gotta get a pyrometer of my own. Maybe I can nail the pressures May 8.
After experimenting in several events, I'm now running 47 all around, and it feels much better. It's hard to get used to on an intellectual level, but my butt definitely likes it.
Reading the old posts, it's hard to imagine running the car with 35 in the rears, like I did first time out.
I shared this with some guys I know who run ZO6s, and they are incredulous. But with the MCS, higher pressure definitely works.
Cheers.
Cheers.
oldkid6
Aug 30, 2015 08:28 AM
