R50/53 No Start R53 with interesting side effects
So this morning I go to start my trusty MINI and all I get is clicking of the starter with my high beams flashing and the drivers window lowering about an inch with every click. Any ideas on what may be going on?
Thanks for the quick responses. I should have prefaced that last Wednesday a Ford Explorer tried to make my MINI his hood ornament and at the moment I am not able to get easily to the battery compartment.
Occams Razor:
Of all possible explanations,
the simplest is usually correct.
Electrical issue(s) most likely related to recent impact.
Assess damage or you could end up with a fire back there if the + batt cable goes to ground.
(if batt is located in back, as in MCS),
I would inspect it asap.
cm.d
Aug 19, 2015 08:51 AM
