R50/53 Handbrake engaged after releasing
Old Jan 22, 2013 | 10:31 PM
twintert's Avatar
twintert
Hey all, this winter has had some record lows for the time I've owned my Mini. I've noticed on the very very cold nights. If I use my handbrake just to be safe when parking, when I come out to my car, put the brake down, and start to drive the brake is still engaged. Usually after driving for just a minute or two it will go back to normal. I'm worried this will be wearing my breaks out, hurting my gas milage and straining my engine. What are your suggestions?
Old Jan 23, 2013 | 12:29 AM
twintert's Avatar
twintert
I'm thinking I may need to get some new parts, but was hoping maybe just a tune up or cleaning an existing one will fix the problem, anyone know anything about this?
Old Jan 23, 2013 | 12:39 AM
Miniman s's Avatar
Miniman s
When was your last brake flush
Old Jan 23, 2013 | 01:41 AM
ViperNL's Avatar
ViperNL
Just don't use your handbrake when ts freezing. Unless you are parking on a hill, it should not be necessary.
Old Jan 23, 2013 | 02:10 AM
MiniMeep's Avatar
MiniMeep
This is coming from Australia but we are told when parking in below freezing temps (ie when we go skiing) to leave the handbrake off when parking the car for exactly the above reason.
Old Jan 23, 2013 | 04:38 AM
cristo's Avatar
cristo
Alliance Member
Cable(s) may be binding or freezing when it's freezing out.
Old Jan 23, 2013 | 08:04 AM
Helix13mini's Avatar
Helix13mini
Your cables are rusted and/or freezing. Replace both of them, clean and re-lube your rear calipers, and you should be fine.
Old Jan 23, 2013 | 10:20 AM
twintert's Avatar
twintert
Good to know! Any suggestions about hill parking? I'll get a brake flush soon, I've not done it since I owned the car.
Old Jan 23, 2013 | 10:57 AM
ZippyNH's Avatar
ZippyNH
Turn you wheels so the car is turning toward the curb....so if it rolls, the curb stops it...
the handbrake DOES NOT USE BRAKE FLUID....it uses cables...that is why helix said to lube/replace tha cables, lube the calipers....
Many stick cars do this...sticky e-brakes in cold weather...kinda of a universal issue on MANY makes/models...bus since so few sticks are getting sold, and folks just use P, with an auto, many have forgotten.
Old Jan 23, 2013 | 02:28 PM
ashchuckton's Avatar
ashchuckton
I never use the E brake for parking in cold wet freezing weather. It is only used for hand brake turns during the winter months.
I've had to replace one cable that was hanging up.
Old Jan 26, 2013 | 04:58 AM
MINIFatherFigure's Avatar
MINIFatherFigure
From: Perth West Australia in an industrial unit with my numerous cars.
When you replace the cables (they are history) don't forget to lube up the rear calipers.
As for the new cables work LOTS of Castrol GRR into them before fitting. And I mean LOTS. It will keep the water out.
Doc Pain
Mar 10, 2021 04:50 AM
RobbyD
Jan 29, 2019 01:22 PM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
MINI Stupor
Oct 1, 2015 11:36 AM
Brochacho
Sep 29, 2015 10:24 AM
