Suspension Clanking coilovers
Old Jan 19, 2013 | 07:18 PM
anonymous1's Avatar
anonymous1
Clanking coilovers
I just installed my ST coilovers today. I think I followed all the instructions correctly, but I didn't torque the nuts/bolts down with any weight on the car (i.e. the car was still jacked up on the jack stands). I also had difficulty tightening down the piston in the shock without it spinning with each turn.
The front end of my car makes a load clanking when going over bumps. When I press on the front end, it makes this noise as well. Do you guys know what could be causing this?
Thanks in advance.
Old Jan 20, 2013 | 07:52 PM
anonymous1's Avatar
anonymous1
Figured it out, it was the nut on the top of the shock. was able tighten it using a loose socket with an alan wrench stuck down the middle.
Old Jan 24, 2013 | 03:35 PM
TheSuspensionSource's Avatar
TheSuspensionSource
That was exactly what I was going to recommend to check. It is a common bolt that is overlooked during install.
RIchard Nguyen
Sep 14, 2016 11:43 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
sssevita
Mar 20, 2016 06:24 AM
CooperSharp
Oct 12, 2015 09:21 AM
gnhovis
Sep 28, 2015 10:56 AM
