R50/53 Question About Horns
Old Jan 19, 2013 | 12:51 PM
Mrelia's Avatar
Mrelia
So, I took my car in for inspection last week and failed because my horn is not working. (It did a couple of months ago when I tootled at someone who hadn't seen the light change, but I rarely use the horn so I don't know how long it's been out.)
The fuse is good and I hear a click from the fuse box which I presume is the relay. At this point I'm thinking it's the horn itself, but I see that there are two of them, one on each side.
If one goes out do they both stop working? Or is there something else I need to check out before opening him up and buying new horns?
Old Jan 19, 2013 | 12:56 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
I'd be absolutely sure the fuse is good by running a continuity test on it or replacing it. Then, I'd check the horns by removing them and applying 12v and ground to each. If they work (and I'm betting they do), I'd suspect either the relay or you've lost a ground connection.
Old Jan 19, 2013 | 01:53 PM
Capt_bj's Avatar
Capt_bj
sad to see so few can figure out the search function - or use Google . .
https://www.northamericanmotoring.co...-went-out.html
come on - this WAS yesterday
if you hear a click but the horns don't toot - given the fact there r 2, I'm guessing the problem is up the line and it sounds like the relay to me
you can sometime free a stuck relay by a sharp tap ......
Old Jan 19, 2013 | 03:59 PM
MINIFatherFigure's Avatar
MINIFatherFigure
From: Perth West Australia in an industrial unit with my numerous cars.
+1 on above checks
Old Jan 19, 2013 | 04:55 PM
Mrelia's Avatar
Mrelia
LOL. I did most of my searching and research LAST weekend.
I think what had happened was one horn went out some time ago but I never noticed because the other worked. Then the other horn went out, which gave me the mistaken impression that BOTH went out at once.
That is why I was concerned that ONE broken horn would prevent the other from functioning. Fortunately, my Bentley manual FINALLY arrived late this afternoon and the wiring diagrams cleared that up question.
I unplugged the horn and tested at the connector and got power. So I picked up a pair of new horns and jury rigged a temporary connection to test it and got melodious tone.
So tomorrow, I'll pull the cover off and replace them.
Thanks for the info.
iclancy82
Jan 2, 2021 08:59 PM
donniedarko
Oct 21, 2015 01:15 PM
one73ronin
23
Sep 22, 2015 09:56 AM
rob&JCW
Sep 10, 2015 12:06 PM
Robree
Sep 9, 2015 08:43 AM
