R50/53 Full boost @ what RPM?
Old Jan 13, 2013 | 12:03 PM
BoostCzaR53's Avatar
BoostCzaR53
Im just curious, at what RPM is everyone making full psi? I know it will vary from setup to setup buy I am just curious to see what setup creates what variances. ..
So do post and let me know and be sure to include what your setup is and "x"psi@xxxxRPM
Old Jan 13, 2013 | 12:06 PM
Braminator's Avatar
Braminator
Mine show about 6700rpm according to my scangauge.
Old Jan 13, 2013 | 12:10 PM
BoostCzaR53
What psi and pulley/setup? On mobile app sorry cant see your sig if listed.
Old Jan 13, 2013 | 12:15 PM
Braminator's Avatar
Braminator
15% pulley at Aprox. 14.5psi
Old Jan 13, 2013 | 12:19 PM
BoostCzaR53
Ever had the car dynoed?
Old Jan 13, 2013 | 12:35 PM
Braminator's Avatar
Braminator
Nope. I should of mentioned I have a slighly modified head also. I am moving to Flordia hopefully next month. Then I will get the injctors and a tune then a dyno test.
Old Jan 13, 2013 | 12:36 PM
BoostCzaR53
Where are you located now just for elevation reference
Old Jan 13, 2013 | 12:49 PM
Braminator's Avatar
Braminator
Pike county PA. My house is at 1400ft above sea level.
Old Jan 13, 2013 | 12:50 PM
BoostCzaR53
Ok so youre about double my elevation roughly, thanks for the info. Gotta pulley tool I can borrow good sir? Lol
Old Jan 13, 2013 | 01:03 PM
Braminator's Avatar
Braminator
I do not. I am sorry. Where are you?
Old Jan 13, 2013 | 01:06 PM
BoostCzaR53
Nc
Old Jan 13, 2013 | 01:17 PM
Braminator's Avatar
Braminator
Start a new thread seeing if anyone in NC is close to you that can loan you one and or help you.
Old Jan 13, 2013 | 01:18 PM
BoostCzaR53
Nobody on the local forum ever gets on, its a wash.
Old Jan 13, 2013 | 01:19 PM
Braminator's Avatar
Braminator
I dont mean local. Do it on here as there are MINIacs all over the place.
Old Jan 14, 2013 | 07:51 AM
AW2mini's Avatar
AW2mini
approx 16.5psi@6700RPM in northern TN
Old Jan 14, 2013 | 09:34 AM
astroBlackMetallic_Mini's Avatar
depends on what gear i guess. ill hit around 15-16 around 2-3k or so (say from 2nd gear, not launching from first), then at maybe 4k the boost gauge tachs out at 18.
JCW with 17%, intake, ect.
Old Jan 15, 2013 | 05:03 AM
Leema's Avatar
Leema
Boost keeps climbing till the limiter. Hits almost 17 psi.
Running mostly stock except for Cai and cat back exhaust with a 17% reduction pulley
Old Jan 15, 2013 | 05:43 AM
Braminator's Avatar
Braminator
Ok, I just tried this again this morning and in 2nd I saw 15.2 at 6500-6600rpm.
Old Jan 15, 2013 | 09:34 AM
ViperNL's Avatar
ViperNL
Yeah, mine does not get that high. It's probably because of the altitude and the temp (it's been around 0F). I tried in second and don't get higher than 5.6 psi, but my gauge starts at -3.4 psi before I start the car (ultragauge) because I'm at 6500 feet here. So I max out at about 9 psi. I'm bone stock still, can't wait to put a pulley and cai on it and maybe an exhaust to get more air flowing through then engine.
Old Jan 17, 2013 | 09:49 PM
Leema's Avatar
Leema
are you at sea level??
im at sea level and have been told i should be getting more boost then 17psi
although i am using a cheap mechanical gauge. may affect things
scan gauge has been ordered so hopefully i can give a more accurate measurement soon!
Matt
Old Jan 18, 2013 | 04:06 AM
Braminator's Avatar
Braminator
Old Jan 18, 2013 | 04:26 AM
Leema's Avatar
Leema
Mmm perhaps my boost is low
Old Jan 18, 2013 | 04:41 PM
BoostCzaR53
Well with a 17% installed and a fresh new belt on (535 belt) I have new info on this subject. Using a Genisys Evo 5 scan tool, reading live data I measured a whopping 12.34psi at WOT/Redline in 3rd gear. 32 degrees outside, 800ft elevation.
I also noticed, after installing the pulley last night my belt tensioner is showing only about 1/2 of the hole on the tensioner strap (the one you put a pin in to hold in place when doing a belt). I also have the VGS setup on the car, idk if maybe I have a leaky bpv?
Suggestions, comments?
Leaky BPV?
Need to run a 532 belt?
I have ruled out wear and tear on the supercharger itself, as I was making a healthy 10.5 psi on stock pulley just a week ago and a stock belt obviously.
Do most ppl go back to factory vacuum routing with a pulley or keep the VGS?
Old Jan 22, 2013 | 10:57 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
You should be pulling 15 lb.+ EZ. Have you tried a smaller belt yet?
Old Jan 29, 2013 | 06:21 PM
BoostCzaR53
Now running a 532 belt, 1 hole visible on the tensioner, I topped out 3rd and 4th gear to reveal a max of 14.6psi using my torque app and bluetooth dongle for obd.
I didnt get any variation of boost level when switching between vgs mod and stock only sooner onset of boost pressure.
It seems as if everybody else is hitting a healthy 15+ with stock setups and 17% pulleys
I feel like I should try with a boost gauge instead of a phone app boost gauge. Any common boost leaks on these cars?
