R50/53 Full boost @ what RPM?
Old Jan 29, 2013 | 06:36 PM
  #26
Braminator's Avatar
Braminator
I measured a whopping 12.34psi at WOT/Redline in 3rd gear. 32 degrees outside, 800ft elevation.
I topped out 3rd and 4th gear to reveal a max of 14.6psi
So the belt helped out. Now the difference with everyone else could be the gauge itself. Some you an actual boost gauge, some use a Scangauge and you are using torque app and bluetooth dongle for obd. So I would say there is the problem. Plus throw in the enviroment factor.
Any common boost leaks on these cars?
We don't typically have those issues like a turbo, but you can check the intercooler couplers.
Old Jan 29, 2013 | 06:42 PM
  #27
BoostCzaR53's Avatar
BoostCzaR53
The black intake tube that feeds the supercharger and has the green oval gasket in it never should theoretically see boost pressure should it? It should be vacuum always correct? I noticed that the brakes felt like they had an issue headed home tonight as if the brake booster was bad, so I got out and checked the line going to the brake booster and if I wiggle it somewhat aggressively I can hear a small hissing indicating a vac leak on that line which leads to that black intake tube? So my theory is if that black tube is pressurized for any reason it could be a boost leak but it shouldn't have positive pressure?
Holy run on paragraph on the mobile app
Old Jan 29, 2013 | 07:06 PM
  #28
Braminator's Avatar
Braminator
Boost leaks common on R53 MINI's are boost leaks from the supercharger horns and the IC couplers. Make sure the IC is sitting correctly in the couplers. The Supercharger Inlet Gasket should be replcaed any time you remove the inlet pipe or supercharger this seal should be replaced as it is very common for it to leak.
Old Jan 29, 2013 | 07:10 PM
  #29
Braminator's Avatar
Braminator
Here is a pic
Old Jan 29, 2013 | 07:11 PM
  #30
BoostCzaR53
Yea it was replaced less then 2k miles ago with the water pump. I am going to do some more investigating I guess I just cant seem to figure out why the psi isnt matching up to other readings.
Whats the avg vacuum you are seeing at idle bram?
Old Jan 29, 2013 | 07:19 PM
  #31
Braminator's Avatar
Braminator
Their are lots of variables for this. Pick up or borrow a Scangauge and see what it is.
I will try to check tomorrow for you.
Old Jan 29, 2013 | 07:28 PM
  #32
ViperNL's Avatar
ViperNL
It should be around -7.6 psi, I believe
Old Jan 29, 2013 | 07:35 PM
  #33
BoostCzaR53
Regardless of condition im going to order a dt bpv, an 02 mcs with 110k is the perfect candidate for a new bypass valve id say. Im too lazy to boost leak test this week so im going to blame it on a leaky bpv until I order one or find my boost leak tester.
Lol had to give me the spec in. -psi huh
  #34
Braminator's Avatar
Braminator
Ok, I will check it now. I did not want to get my *** off the couch. Thx Viper
Old Jan 29, 2013 | 07:37 PM
  #35
Braminator's Avatar
Braminator
I am at -7.8/7.9
Old Jan 29, 2013 | 07:39 PM
  #36
BoostCzaR53
Roughly 15-16in-hg?
Old Jan 29, 2013 | 07:42 PM
  #37
Braminator's Avatar
Braminator
I get 15.88
Old Jan 29, 2013 | 08:25 PM
  #38
ViperNL's Avatar
ViperNL
Haha, google is was my friend, but I feel sorta accomplished that I can make you move here
Oh and yes, a vacuum is negative psi
Old Jan 30, 2013 | 04:00 AM
  #39
Braminator's Avatar
Braminator
Old Jan 30, 2013 | 04:15 AM
  #40
Leema's Avatar
Leema
Decided to give it a push in second gear to redline with a more accurate gauge and im pushing 18.9 psi. That's with a 17% pulley. Chargers brand new and I adjusted to bpv to close fully. Very happy with the amount of boost!
Old Jan 30, 2013 | 04:22 AM
  #41
Braminator's Avatar
Braminator
Old Feb 2, 2013 | 04:16 PM
  #42
scoopy's Avatar
scoopy
using torque app i get 16.5-16.7 psi at wot with 17% pulley
Old Feb 3, 2013 | 09:05 PM
  #43
BoostCzaR53
Man im still falling short at 15.3-15.5 psi at wot and im only 800ft above sea level with 40 degree temps. I did notice that the pulley really heats up the air charge reaaaaaly quick!
Anybody used any of those ebay gp intercooler knockoffs? I dont have a cool half grand laying around for a legit one
Old Sep 2, 2013 | 12:27 PM
  #44
animal1's Avatar
animal1
<Yeah, mine does not get that high. It's probably because of the altitude and the temp (it's been around 0F). I tried in second and don't get higher than 5.6 psi, but my gauge starts at -3.4 psi before I start the car (ultragauge) because I'm at 6500 feet here. So I max out at about 9 psi. I'm bone stock still, can't wait to put a pulley and cai on it and maybe an exhaust to get more air flowing through then engine. >
If you look at the manifold drivers side you will see the throttle body at the bottom about 1 o clock, see the little vacuum valve next to it? Looks like a little EGR valve?
This may be bad, it is the pressure dump for the system
and can cause issues with weak boost on gen 1 s models. wire it so it is secured against the little set screw at rest. The fire it up and hold on to the steering wheel!!!!
Old Sep 2, 2013 | 12:34 PM
  #45
ViperNL's Avatar
ViperNL
thanks, I'll check it out, I put a 17% pulley on it and now get about 14 psi or so at 4500ft. So it's a lot better. Unfortunately i just got a P2096 code that I need to fix...
carid
Dec 28, 2025 04:11 AM
actualsize37
Nov 18, 2015 08:58 AM
embiggenedmini
Oct 15, 2015 12:36 PM
molala
Oct 2, 2015 01:53 PM
Sep 2, 2015 11:15 AM
