R56 r56 non-s question
Old Jan 12, 2013 | 03:44 PM
miniSherlock92's Avatar
miniSherlock92
r56 non-s question
Does anyone know if stock 2012 jcw struts, shocks, and sway bars will fit a 2012 Cooper? I know the sway bar is thicker so I need mounts too, but is it wider or anything? I don't want to drop the subframe to find out, I have to mod so things...
Any info will help, thanks.
Old Jan 12, 2013 | 04:07 PM
Braminator's Avatar
Braminator
Yes it will fit. You will need to change the sway bar mounts like you mentioned.
Old Jan 12, 2013 | 04:16 PM
miniSherlock92
Thanks a lot. Know anyone who has done it?
Old Jan 13, 2013 | 05:10 AM
THE ITCH's Avatar
THE ITCH
miniSherlock92
Just be sure that you are actually getting JCW components. JCW springs are alwas red. Also the JCW suspension is specked to the weight of your car depending on options, sun roof ect.. You can buy a JCW car with stock, sport, or JCW springs, struts/shocks. They are all options. I have seen several marketplace sales that state JCW suspension ( which was from a JCW car) but in reality was the stock or sport suspension. In any case they will all fit.
Steve
Old Jan 13, 2013 | 02:38 PM
miniSherlock92
I said they were from a stock jcw. The gentleman had jcw suspension installed at dealer. And I had the opportunity to acquire his brand new jcw stock suspension with no miles on them. The front struts say sport and the rear say Cooper s. The springs are black.
Old Jan 14, 2013 | 04:57 AM
THE ITCH's Avatar
THE ITCH
miniSherlock92
Well aparently what you bought is the sport suspension which is an option over the standard suspension. If you had the sport suspension on your Cooper it would be the same thing. You can check the part numbers at
realoem.com.
Steve
Old Jan 14, 2013 | 07:46 AM
strobeyprobey's Avatar
strobeyprobey
Unfortunately, the part numbers for the springs is not an RealOEM, you need to go find the BMW ETK program to look those up.
Hippiehobbit267
Dec 3, 2019 04:22 PM
boostedhaze
Jan 2, 2018 07:26 PM
thebordella
Aug 31, 2015 01:37 PM
polotska
Aug 23, 2015 09:10 AM
Shelly Cooper
Aug 10, 2015 12:05 PM
