Jcw brake rotors
Old Jan 11, 2013 | 10:32 AM
adamMCS2007's Avatar
adamMCS2007
Jcw brake rotors
My MCS needs new rotors. Is it worth the extra expense to upgrade to jcw rotors?
Old Jan 11, 2013 | 11:01 AM
Braminator's Avatar
Braminator
If you have JCW calipers then yes. If you don't they wont fit. R56 MCS can use the R53 JCW rotors.
Old Jan 11, 2013 | 12:35 PM
timtim's Avatar
timtim
You can use the R53 JCW rotors on your stock R56 MCS. Both discs are 294MM x 22MM but the R53 JCW discs are slotted and cross drilled. There are a number of aftermarket offerings that are available for the R56 MCS that are coated or slotted or cross drilled etc. Look around a bit!
Old Jan 11, 2013 | 12:43 PM
martinb's Avatar
martinb
I highly recommend Centric slotted rotors. I bought a set of the JCW slotted and drilled for my 06 JCW (it came with plain rotors) but they were expensive (of course) and now I find that for the most part, drilled rotors aren't that desireable from a performance standpoint and since Centric and StopTech are now one in the same, the Centric slotted rotors just make sense. Cryo treated is optional. They'll last a bit longer, but then they cost more as well.
Toolman
Jan 20, 2016 06:50 AM
aldito2
Nov 25, 2015 09:33 PM
thebordella
Aug 31, 2015 01:37 PM
fjork_duf
Tires, Wheels, & Brakes
Aug 16, 2015 04:38 PM
