R50/53 Lights on tachometer bettwen #5 & #6
Old Apr 7, 2004 | 10:43 PM
aziandoll
Hi guys, I know I haven't posted in a while, but I had a quick question.. On your tachometer (that thing above the steering wheel, right?), do the lights between#5 and #6 light up? Or, are they dark all the time? My lights from #6 and higher are always lit. I also noticed that even with the lights on, the lights between #5 and #6 dont' light up at all. Do I need to have this fixed right away? I just noticed in in February, when I had my car serviced and had my temperature changed from celsius to fahrenheit. Anyhow.. I look forward to your replies!
Old Apr 7, 2004 | 11:06 PM
Nick_T.'s Avatar
Nick_T.
If you will take a closer look you'll see that the lines that have lights are red. This means that driving with the engine RPMs in this zone is prohibited because it will cause damage to the engine.
Old Apr 8, 2004 | 07:06 AM
C4's Avatar
C4
Yep, this is the engine's "red line" zone or otherwise known as the "forbidden" zone if you want your engine to last.
If you have a regular Cooper 5-speed or a CVT model, the red line begins at 6K RPM. If you have a MCS, your redline will start at 6,800 RPM.
Old Apr 8, 2004 | 07:09 AM
sdanaher's Avatar
sdanaher
wait.. my redline is at 6000 rpms? im obviously not in my car right now, but that doesnt sound right (5-speed)
Old Apr 8, 2004 | 07:21 AM
C4's Avatar
C4
Yes it should be. Earlier Cooper CVT's (Like mine) have the redline at 5,500RPM, but 5-speeds should start at 6K RPM>
Old Apr 8, 2004 | 07:30 AM
Johnna's Avatar
Johnna
Hmmmmm ..... my 2002 MC 5 speed has the redline at 6800. Anybody else?
Old Apr 8, 2004 | 07:50 AM
mini-rolls's Avatar
mini-rolls
The redline on my 2003 MC CVT was at 5500 prior to the install of v36.0 software. After v36.0 the redline change to 6000, so when you had the temp changed to "F " from "C" they may have upgraded you to v36.0 which raised the redline. And I can tell you that the CVT now shifts at 6000 vs 5500 when I an driving very hard and I have enjoyed that alot more. Drive it, push it, redline it!!!!!!
Dave
MINI-Rolls
Old Apr 8, 2004 | 07:53 AM
sdanaher's Avatar
sdanaher
I'll verify at lunch.. but i am 99% sure mine redlines at 6800 (5-speed)
Old Apr 8, 2004 | 08:02 AM
countrym's Avatar
countrym
I'm kind of curious about this whole tachometer lighting question.
On my MCS, there are a series of lights starting from about 600 and going all the way up to the top, 8000 I guess. As you guys know, only some of the lights light up red, the others stay unlit and appear gray.
Here's my question. Is the car's ECU calculating a red line based on some variable factors and deciding where to start lighting up the red part of the tach? Or is the model of your car the deciding factor?
Old Apr 8, 2004 | 08:04 AM
dandp's Avatar
dandp
6800 RPM's on an MC, then you hit rev limiter....always fun
I beleive cooper4us meant that the MC "zone" STARTS at 6000 RPM's....not ends.
_________________
Old Apr 8, 2004 | 08:06 AM
sdanaher's Avatar
sdanaher
rev limiter... i love you. actually though.. is 6800 the "best" place to shift.. i always feel like I am accelerating better when i shift at like 5800-6000
Old Apr 8, 2004 | 11:58 AM
KatanaPilot's Avatar
KatanaPilot
MINI uses the same techometer in all their cars. Based on your model, different number of bars are lit to indicate different red-line RPMs. This is probably done as a cost saving measure. The red-line stays the same in your car (unless a software upgrade changes your red-line RPM).
Old Apr 8, 2004 | 12:03 PM
C4's Avatar
C4
>>Dave
>>MINI-Rolls
The 5.5K RPM redline in our '02 CVT did not change after V36 was installed.
Old Apr 9, 2004 | 10:51 AM
aziandoll
Hm, I guess I forgot to mention I drive a 2002 CVT. All I know is that there are absolutely no lights between 5000 and 6000 rpms (even with the headlights on), and from 6000 and up, the red lights are on all the time. I was just wondering if I needed a new bulb or something, if there is one between the #5 and #6.
But I did have a software upgrade, and before the lights between 5000 rpm and 6000rpm were always lit.
Old Apr 10, 2004 | 08:15 AM
aziandoll
You know, I get it now.
triple5soul
Nov 19, 2019 07:46 AM
triple5soul
21
Jul 29, 2016 04:27 AM
Aug 19, 2015 12:51 PM
stellaherself
Aug 14, 2015 05:28 AM
