R56 R56 weight distribution ??
Old Jan 10, 2013 | 04:02 PM
shaolin29's Avatar
shaolin29
Extremely newbie question alert!!
Common sense tells me that the weight distribution of R56's have the front being heavier than the rear. I'm right right? Right!?
Old Jan 10, 2013 | 04:08 PM
Porthos's Avatar
Porthos
Umm yeah.
Old Jan 10, 2013 | 04:12 PM
countryboyshane's Avatar
countryboyshane
It's around 60/40
Old Jan 10, 2013 | 05:01 PM
shaolin29's Avatar
shaolin29
Originally Posted by countryboyshane
It's around 60/40
I thought so.
So, say, if a person had neglected regular tire rotations and had the two rears with more tread compared to the front, that he/she just swap them out? Perhaps, theoretically, having them eventually even out?
Old Jan 10, 2013 | 07:03 PM
Jay H's Avatar
Jay H
Since on a front drive car, the front tires typically wear quicker than the rears, yes, you could bring the rear tires forward and put the fronts on the rear. Eventually the fronts (formerly the rears) would wear down a bit more so that the difference in tread depth between front and rear would be less than it is now.
Keep in mind that all tires wear on all corners of the car. So, if the fronts are seriously low in tread depth, the safest thing would be to replace the worn front tires with new, matching tires so that you have good tread depth on all four corners of the car.
Old Jan 10, 2013 | 07:58 PM
shaolin29's Avatar
shaolin29
Thanks Jay H for confirming my thoughts. I put the tires with more tread up front and the "older/more worn" tires in on the rear. The corners seem to have worn evenly, so I think it's safe for a few thousand miles. I'm just trying to be a cheapskate and get the most out of the tires now prior to buying a new set of 4.
Old Jan 11, 2013 | 04:28 AM
countryboyshane
Just rotate them every oil change and you'll get the most out of them. And of course, don't follow the MINI recommended oil change interval :-0
battlehawk_mini
Mar 5, 2021 06:15 AM
rtk90
Aug 29, 2019 09:08 AM
Llanrhaeadr_Cymru
Country Roads MINIs
Sep 2, 2015 07:12 PM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
