Interior/Exterior Different Tachometer
Old Apr 7, 2004 | 09:53 PM
bigpmj's Avatar
bigpmj
Has anyone installed a different tachometer in place of their factory one? I did a search, but couldnt find anything.
title changed by Ryephile to be more concise
Old Apr 7, 2004 | 09:59 PM
Ryephile's Avatar
Ryephile
Do you mean something like this?
also, moving to int/ext. mods forum
Old Apr 7, 2004 | 10:01 PM
bigpmj's Avatar
bigpmj
Precisely. I remember in my Mustang, Ford was known for having HORRIBLY poor tachometers, and if you wanted to drive the car hard, you pretty much had to get an aftermarket one.
Old Apr 8, 2004 | 09:47 AM
Trippy's Avatar
Trippy
I took my tachometer apart, and it is going to be real hard to find an aftermarket tachometer that hooks up the same way.
Out tachometer cluster sits on something called a Controller Area Network (CAN) bus which sends messages to the tachometer telling it which lights to light, and where to put the tachometer needle.
It might be possible for an aftermarket vendor to splice into the crankshaft position sensor and display the engine RPM on a meter, but it could be tricky. I don't know.
It looks like this MG uses a crankshaft position sensor for its signal, so maybe there ARE aftermarkey tachometers out there.
Let us know what you find out.
Old Apr 8, 2004 | 12:44 PM
BC28's Avatar
BC28
The first issue is the factory idiot lights-
In theory, you can install the center speedo section of the Mini One. The One does NOT come with a column mounted tach and all the idiot lights are contained in the center speedo section. You will need to have the dealer code this setup though.
Now you are free to place any aftermarket tach on the steering column and STILL have factory idiot lights.
The second issue is the coil signal-
Depending on who makes the tach you may need to install a Tach Driver so your new tach can read the signal from the coil correctly.
Click here for tach adapter.
Old Apr 8, 2004 | 12:50 PM
Bisch's Avatar
Bisch
Trippy, does the face (bezel) of the tach just pry off? How did you remove it? I'm brainstorming an idea and need to remove my face...thanks.
...let me clarify...just the clear lens and ring, not the dial face.
_________________
MCS, with some stuff. Stuff. Just stuff, alright!
Old Apr 8, 2004 | 12:51 PM
C4's Avatar
C4
He would have to order a MINI ONE center speedo directly from the UK, as the MINI ONE model is not sold in the US or Canada.
Will it work on a US spec Cooper or MCS?
I have no idea.
Old Apr 8, 2004 | 12:57 PM
bigpmj's Avatar
bigpmj
Is the stock tach in the Cooper S pretty accurate, so theres really no need for an aftermarket one?
Old Apr 8, 2004 | 01:00 PM
BC28's Avatar
BC28
>>I have no idea.
Some more info: Here is MINI's fitting guide for retrofitting the factory tach in the MINI One: If you can add a tach, I cant see why you cant remove it.
CLICK HERE FOR TACH FITTING GUIDE
Old Apr 8, 2004 | 02:54 PM
Trippy's Avatar
Trippy
No it does not.
Remove the tach from the steering column using a Torx wrench, unplug the connector and then unscrew the fasteners from the back of the case and it comes apart.
I can't remember of they have the phillips head screws filled with solder like the speedo cluster or not.
Speedo-insides
_________________
Old Apr 8, 2004 | 03:19 PM
10851CS's Avatar
10851CS
Can the speaker in the center console be the click when your turn signal is on?
Just curious but why did you take your stuff apart?? Looking to make an improved version??
Earl
Old Apr 9, 2004 | 07:30 AM
Trippy's Avatar
Trippy
I like this look better
and I'm looking at making a modified tach with just a very low profile bar of LEDs for indicator lights and a bar for the RPM indicator.
Old Apr 9, 2004 | 12:09 PM
Mini_Street_Racer's Avatar
Mini_Street_Racer
how about this?
Old Apr 9, 2004 | 01:52 PM
Trippy's Avatar
Trippy
I don't like it at all.
But, it's not going into my car, so if you like it, you should get it.
I don't need to know the exact, precise RPM, just approximate is fine with me.
Different people have different likes and dislikes.
Old Apr 10, 2004 | 12:04 AM
Mini_Street_Racer
I think there's one made by Pilot, which is just a stand alone shift light, (no numbers) similar to the ones used in the JC challenge, (you could see a few of them using it in the video) But for the life of me I cant seem to remember the webpage. (have their catalog though, no web page) I'll try to get access to a scanner.
unless of course you're planning to make one your self.
Old Apr 10, 2004 | 03:26 AM
BC28's Avatar
BC28
I think you meant this Pivot one:
CLICK HERE TO SEE LAMP IN ACTION
go to http://www.pivotusa.com -it is model #pivssl-p
Old Apr 10, 2004 | 04:30 AM
Mini_Street_Racer
'xactly! thanks.
Old Apr 10, 2004 | 01:53 PM
Bisch's Avatar
Bisch
Here's a product that will give Trippy something to evaluate. Kinda like the Plasma Booster debate.
Old Feb 27, 2006 | 10:33 PM
Motor On's Avatar
Motor On
I know old thread, but new project. I was wondering if you could update your link for me.
Old Feb 27, 2006 | 11:58 PM
pfunk's Avatar
pfunk
There is always a JDM solution
Dry carbon mount for Stack Tach meter
Old Jun 2, 2006 | 07:37 PM
MSFIT's Avatar
MSFIT
^^ how much pfunk?
Old Jun 3, 2006 | 03:03 AM
UKSUV's Avatar
UKSUV
So....I ask the same questions awhile back and no one responds.
triple5soul
Nov 19, 2019 07:46 AM
triple5soul
21
Jul 29, 2016 04:27 AM
stellaherself
Aug 14, 2015 05:28 AM
