Passenger Air Bag Light off
Old Jan 10, 2013 | 07:54 AM
HarlequinAuthor's Avatar
HarlequinAuthor
I have been searching the forums about the Passenger Air Bag Off issue but I haven't seen my problem so I am going to ask all of you.
I just purchased a 2010 Hatchback (R56) noticed when my dog rides in the front seat (I know he shouldn't but he jumps up there) the Passenger Air Bag Off light comes on and off The seat belt is not engaged. My dog weighs 20lbs.
I am assuming this is a safety mechanism but I wanted to double check. I haven't noticed it coming on with a passenger in the seat.
Any help is appreciated.
Thank you!
Old Jan 10, 2013 | 09:26 AM
strobeyprobey's Avatar
strobeyprobey
Yep, that is normal behavior. You will see that with weight on the seat (approximately kid weight) or a child seat.
Old Oct 1, 2014 | 05:57 AM
coachvminis's Avatar
coachvminis
Ok I have a question to that as well..My Air-bag light wont go out! Pass side..I disconnected the battery thinking it would reset..Whats up?
PITA! it won't go out! how do I reset disconnect or whatever whats the fix?
Old Jan 28, 2015 | 04:58 PM
2014-JCW's Avatar
2014-JCW
I'm going to wake up an old topic. The "passenger air bag off" light will come and stay on anytime no one or smaller passenger is sitting in the front passenger seat. This is normal for most cars. The passenger front seat has a front occupant classification system, sometimes known as smart air bag system. It detects the weight of passenger sitting on the front passengerseat. The system then determines in some collisions whether or not it should allow the passenger airbag to deploy and/or the force of deployment.
The passenger airbag off light comes on and off on my Countryman JCW. BUt my issue is caused by something else. My iPad mini. I will explain on another post.
Old Jan 28, 2015 | 05:50 PM
rkw's Avatar
rkw
That is NOT the issue discussed in this thread. The weight sensor mat fails, and the light will stay on with or without an adult passenger in the seat. This is not normal and a safety hazard.
Edit: clarification... I was referring to coachvminis post, not the original thread post.
Old Jan 29, 2015 | 08:55 AM
coachvminis
Ok! so where is this sensor located so I can replace
Old Jan 29, 2015 | 08:58 AM
u238's Avatar
u238
It's a large, flexible printed circuit board inside the seat.
Old Jan 29, 2015 | 09:25 AM
rkw's Avatar
rkw
This is what it looks like, after removal from the seat bottom.
The topic is discussed at length in this thread: https://www.northamericanmotoring.co...t-no-more.html
Old Jan 29, 2015 | 03:25 PM
2014-JCW's Avatar
2014-JCW
I'm not familiar at all that the Mini has a problem with the passenger seat sensor. I have a 2014 Countryman JCW with leather seats. Is there anything I need to know?
Old Jan 29, 2015 | 07:06 PM
rkw's Avatar
rkw
BMW as well: http://brandilawblog.com/2013/12/26/...g-mat-failure/. MINI from this era (2005-2008) probably use the same sensor as BMW, but there weren't enough complaints to trigger a recall. Hopefully they've resolved it in later years.
Old Jan 29, 2015 | 07:20 PM
2014-JCW's Avatar
2014-JCW
Well, this is what is going on with the passenger airbag on my 2014 countryman JCW. My Ipad Mini is the cause, really?
https://www.northamericanmotoring.co...lfunction.html
W0TM8
Dec 19, 2019 07:50 AM
bneer
Jul 15, 2019 04:41 PM
nismo4life
Nov 4, 2015 09:18 PM
Zettinger
Aug 25, 2015 04:04 PM
