R56 After market wheels
Old Jan 10, 2013 | 07:54 AM
marbleme2's Avatar
marbleme2
After market wheels
I have a 1213 MINI S---what offset do I need 2 look 4 in after market wheels that would b close 2 factory wheels ?
Old Jan 10, 2013 | 09:15 AM
myR56S's Avatar
myR56S
That question is a good one but a broad one too. Pending on the diameter I have seen everything from 35mm to 45mm. Most wheels found at tire stores will have the offset listed for the specific wheel you are interested in.
My Sparcos are a 18"x8" and feature a 45mm offset with 5.9" of backspacing.
Old Jan 10, 2013 | 10:52 AM
Slave to Felines's Avatar
Slave to Felines
A handy list of OEM wheels can be found here:
http://www.mini2.com/forum/faq.php?f...factory_wheels
Match the dimensions there (assuming the same generation of MINI) and you should be fine. There's probably some leeway in width and offset, too, but that's less easy to quantify.
Old Jan 11, 2013 | 06:05 AM
DrewN's Avatar
DrewN
Nm
Aug 19, 2015 12:51 PM
Aug 19, 2015 12:34 PM
Aug 19, 2015 12:33 PM
Aug 19, 2015 12:21 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
