R56 how do you check the oil temperature?
especially R56 models don't have any functions to check the oil temperature right?
these days I went to several sevice shop and they told me that i need to replace the thermostat. thermostat matters to oil temperature right?
is there any ways to check the oil temperature?
There are electronic gages that plug into the OBD2 connector, that will show you many different temperatures and pressures. Scangauge 2 and Aeroforce interceptor are two examples.
http://www.scangauge.com/products/scangaugeii/
http://www.aeroforcetech.com/products_interceptor.html
There are also smartphone apps that work with a transmitter plugged into the OBD2 connector that will display data on your phone.
I installed analog water and oil temperature gages as well as oil pressure and boost gages in my MINI, 'cause I like the look.
For thermostat problems you would want to watch the water temperature, rather than the oil temperature.
Dave
Dave
Are you seeing oil temperature broadcast over OBDII? I thought the N14 engine didn't even have an oil temperature sensor because of cost cutting.
I always though you had to tap a hole for a temperature sensor in the oil pan and have a separate gauge installed for oil temp
I got the ScanGuage Beta update described in the followin post. This update reads the oil temperature on my 2011 MC plus many other nice readouts.
https://www.northamericanmotoring.co...577-post1.html
Morris, 2011 MC, PW/B
Dave
