Suspension Stock R56 fit R50?
Old Jan 6, 2013 | 01:54 PM
zx9rider's Avatar
zx9rider
Stock suspension from 08 MCS fit 03 MC?
Will the stock suspension from a 2008 MCS fit my 03 MC (Non-S R50)? Thanks for all replies.
Old Jan 10, 2013 | 03:18 PM
dubstepsteve's Avatar
dubstepsteve
Yessir
Old Jan 11, 2013 | 01:34 PM
andyroo's Avatar
andyroo
Uhhh no it won't.
Old Jan 11, 2013 | 02:15 PM
Braminator's Avatar
Braminator
Old Jan 11, 2013 | 03:05 PM
dubstepsteve
True! My mistake I got confused
Old Jan 11, 2013 | 03:34 PM
zx9rider's Avatar
zx9rider
Thank you.
Old Jan 11, 2013 | 07:09 PM
r34king's Avatar
r34king
The front brakes will fit provided you have 16 or bigger rims. The suspension will not
Old Jan 11, 2013 | 08:33 PM
zx9rider's Avatar
zx9rider
That's a bummer because my old 03's struts are getting really tired and a local guy has a low mileage set of struts cheap from his 08 MCS.
Old Jan 11, 2013 | 09:09 PM
blue2turbo's Avatar
blue2turbo
If you're looking for an OEM replacement, if you shop around, you can find some Bilstein Touring shocks for a couple hundred bucks new.
Or you could take a chance on the ebay specials and let us know how they are
http://www.ebay.com/itm/STAGG-4-SHOC...51cb28&vxp=mtr
Old Jan 12, 2013 | 05:50 AM
rjtrout2000's Avatar
rjtrout2000
I smell an awesome budget project in the works...
But in all seriousness, Koni is running a lot of sales across their vendor range right now and you could get either a set of yellows or FSD for a good price and have a solid upgrade to boot! Just my. 02.
Old Jan 23, 2013 | 02:28 AM
1SuperCooper1's Avatar
1SuperCooper1
I´m not sure, but in my opinion best way to go is Bilstein´s B6 or B8/B12 if you want your car lowered.
There are more options, and here in Spain we make a bespoke dampers with very good results, but this is another story.
Old Jan 23, 2013 | 07:40 AM
andyroo's Avatar
andyroo
What dampers do you make in Spain?
Old Jan 23, 2013 | 08:16 AM
1SuperCooper1
We make bespoke dampers to suit every application or customer needs. They are different for each car and customer depending on weight per wheel, driving style, customer preferences, spring ratio and so on.
Front is bi-tube and rear monotube and we just use best parts available. As I´m not a vendor here, and don´t want to be illegal, I can send you by private the graphics comparing it with the JCW shocks and tech specs if you want to learn more about this.
Old Jan 23, 2013 | 11:53 PM
ColinGreene's Avatar
ColinGreene
Interesting.
Old Jan 24, 2013 | 12:57 AM
blue2turbo's Avatar
blue2turbo
Are you a Bespoke dealer? or work for Bespoke suspensions? I ask because I have a set of Fortune Auto 500 Series Coilovers that I believe use Bespoke dampers.
Old Jan 24, 2013 | 01:13 AM
1SuperCooper1
We manufacture bespoke dampers. Bespoke isn´t a brand. Our brand is Just Mini Racing. It is a "normal" damper perfectly matched to different springs (OEM, Eibach and H&R) with different piston rod, valves, oil and gas pressures. Each damper is made to suit just one customer, his car weights and driving style or preferences and can be made to street/comfort, street/handling, fast road, extreme road/rally, circuit, gravel, and so on. Also we can make 1, 2 or 3-way dampers or coilovers using best materials available.
We also produce fixed and adjustable front camber plates that don´t modify ride height, finishing at this moment adjustable trailing arms and special brake pads and studying and designing a 4-pot brake caliper kit to suit the OEM discs sizes (276x22/280X22/294X22) and to be fitted on 15" wheels if the customer wants it.
I´m not here as a vendor, just to learn and to teach about our experiences, so please forgive me about this post.
Old Jan 24, 2013 | 03:31 AM
blue2turbo's Avatar
blue2turbo
Ah ok, I just know my Fortune Coilovers have "Bespoke Suspension Systems" stamped on it, that's why I asked. Mine have custom valving for my car as they installed and tweaked them using my car as the test bed.
I was just curious because when I bought them, I hadn't heard of bespoke suspensions before and saw your post about it. Either way, I love the Fortune coilovers and they are very high quality products.
Old Jan 24, 2013 | 05:43 AM
Braminator's Avatar
Braminator
How about a link to your brand?
Emnotek
Aug 13, 2015 05:47 PM
Aug 12, 2015 01:24 PM
Accessory Products
Aug 11, 2015 12:59 PM
Aug 11, 2015 12:58 PM
WayMotorWorks
Aug 4, 2015 01:47 PM
