R56 Where is the pcv valve?
Old Dec 31, 2012 | 02:31 PM
Yslee's Avatar
Yslee
I have a MCS, and want to spray Seafoam into the PCV valve. I have a feeling that its the mesh pipe the connects to the engine at the top left (facing the car). I just want to be sure before I spray it into a wrong area. Also do I spray it into the hose or where the hose connects to?
Old Dec 31, 2012 | 03:02 PM
Porthos's Avatar
Porthos
That little hose between the one the left and the box.
Old Dec 31, 2012 | 03:20 PM
Yslee's Avatar
Yslee
I see three hoses. Two meshed. Is it the bigger meshed one, and not the tiny one?
Also when I remove the pcv hose, in which direction do I spray the seafoam into? Into the hose?
Old Dec 31, 2012 | 03:42 PM
Braminator's Avatar
Braminator
Maybe this will help.
https://www.northamericanmotoring.co...t-r55-r56.html
Old Dec 31, 2012 | 05:19 PM
Porthos's Avatar
Porthos
It is the large mesh one right in the middle between the airbox and the coldside intake tube. The one with the clip attached to the corner of the valve cover.
Old Dec 31, 2012 | 05:21 PM
Yslee's Avatar
Yslee
Thanks!
Old Oct 29, 2013 | 07:03 PM
Grosbec's Avatar
Grosbec
Thanks for this video. I was gonna Seafoam my sons 2009 Mini Cooper but no other videos show the vacum hose in that location. I was going to pour into it but wasn't 100% sure. Now I am.
My repair manual shows another crank case hose on the right side of the motor also but my engine doesn't seem to have the same setup. Manual shows pics of MK II engine which is correct, but there is no large hose on the driver side like in there picture. So where exactly is the CPV valve located on this motor. I originally thought that's where the Seafoam would go. Anyway I now see that it goes on the opposite end. When I put the Seafoam into the proper hose, where does it circulate through? I didn't know if it would mix with the oil in the pan or not. I'm not due a oil change and wasn't sure if I would have to change the oil after.
Old Oct 29, 2013 | 07:19 PM
cerenkov's Avatar
cerenkov
The PCV valve itself is integrated into the valve cover. You can't actually see it.
Old Oct 29, 2013 | 07:29 PM
Grosbec's Avatar
Grosbec
So when I'm facing the car, the braded covered hose that I detached at the back left side of the valve cover, you are saying the intergraded CPV valve is located right there inside the valve cover?
If that's correct, can I ever change just CPV valve?
Old Oct 29, 2013 | 07:59 PM
cerenkov's Avatar
cerenkov
No I don't believe that you can. Here's some diagrams of a N18 engine.
Old Oct 30, 2013 | 02:10 PM
Grosbec's Avatar
Grosbec
Ok thanks. I appreciate the feedback.
Old Oct 31, 2013 | 01:17 AM
danigurrl's Avatar
danigurrl
So is #3 the PCV valve hose?
Old Oct 31, 2013 | 02:55 AM
cerenkov's Avatar
cerenkov
Yes #3 is the PCV hose for a N18 engine, if you have a N14 engine I believe that it is different. The diagrams are located at realoem.com
Old Oct 31, 2013 | 03:06 AM
danigurrl's Avatar
danigurrl
I blocked it off when I put on my CAI because I didn't know what it went to. hahaha. We let it just flow into the engine bay, then later put a plug in it. 20k miles...no troubles. I need a catch can!
olson187
Oct 21, 2015 05:25 AM
Fordgt4
Oct 10, 2015 10:42 AM
Southern Marylander
Oct 1, 2015 07:53 AM
micromini234
Sep 30, 2015 07:36 PM
Emnotek
Sep 29, 2015 07:37 AM
