R50/53 r53 won't start, window going down when key is turned
Old Dec 31, 2012 | 11:38 AM
swunder's Avatar
swunder
04 r53 with 60k, when I turn the key even just into the on position the dash clicks and the displays blink on and off while the driver side window slowly clicks its way down. No response from anything, though I can still lock and unlock the doors with the key fob.
Any ideas?
Old Dec 31, 2012 | 11:45 AM
Tom D's Avatar
Tom D
Really strange things happen to MINI's when the battery is low. I would try that first.
Tom
Old Dec 31, 2012 | 11:50 AM
LethalR53's Avatar
LethalR53
Happend to me 2 weeks ago, your battery is drained. It happend while I was at the carwash so the guys pushed the car down a road, and I jumpstarted it never gave me a problem after that
Old Dec 31, 2012 | 11:52 AM
LethalR53's Avatar
LethalR53
I should add that mine is also an 04 R53, and I'm still running the original battery which came from the factory.
Old Dec 31, 2012 | 11:56 AM
LethalR53's Avatar
LethalR53
Also,When mine was drained the indicators flashed and the wipers made a noise, can't remember if there was any activitiy with windows, but that click is "normal" I think . I remember the same click noise in my dads old bmw e46 when his battery was drained.
Old Dec 31, 2012 | 12:03 PM
BSTINS's Avatar
BSTINS
Battery. Same thing happened with my 2003 R53
Old Dec 31, 2012 | 12:11 PM
swunder's Avatar
swunder
Thanks for the quick response everyone, will attempt a jump soon.
Any battery suggestions? The battery for my dads justa was some weird size that was hard to find.
Old Dec 31, 2012 | 12:14 PM
Braminator's Avatar
Braminator
Optima Redtop
Old Dec 31, 2012 | 12:18 PM
dannyhavok's Avatar
dannyhavok
Mine behaved strangely with a dying batter as well, very similar. It lowered the windows (in the pouring rain!) and then didn't have enough juice to get them back up. I was on the verge of a nervous breakdown.
I went with an OEM battery... after all, the first one worked great for six years.
Old Dec 31, 2012 | 12:51 PM
KMalinich's Avatar
KMalinich
I installed an HID kit with ballasts into the stock wiring and the pulsing from the computer (the cold bulb check) made it do all sorts of weird stuff, namely not activating the alternator. After the battery got low, my traction control wouldn't turn back on, the window moved by itself, the ABS didn't work, and it was acting like the fan wouldn't run either. After a capacitor was installed inline before the ballast (absorbing the pulses) the problem fixed itself.
Old Dec 31, 2012 | 03:21 PM
swunder's Avatar
swunder
Thanks guys, it was the battery. Was an Exide that failed after 6 years. I picked up an Autocraft from advance auto and its all good now.
iggi
18
Feb 9, 2026 01:00 AM
09R56
Nov 16, 2022 10:49 AM
Lt. Dan
Aug 10, 2015 12:46 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
