Looking for shop to diagnose my mini in Fairfield/Litchfield..
I registered a cam shaft sensor code last night, the engine was jumping.. Brought her home, and this morning wouldn't start. Tried too but didn't. Don't want to go the dealer in Fairfield/Darien.. Is this hard to fix? I found another thread on here with the same issue.. I don't want to replace it and if it be the timing belt... Thoughts?
Below are the instructions from Bentley...
Remove engine vibration bracket
Remove fuel line bracket bolt and set the bracket aside
Remove fuel tank vent valve
Support oil pan with a jack
Remove right side engine mounting bracket
Remove engine ground cable
Remove 4 engine mounting bolts from engine block
Lift motor
Working at the right end of cylinder head, unlock and detach camshaft sensor electrical harness connector
Unscrew sensor mounting bolt and remove sensor
When installing, lubricate sealing o-ring antiseize paste
Torque down to 9nm (7 ft-lb)
Lift motor
bc219
Aug 10, 2015 11:22 AM
