My poor mini was vandalized! HELP!
Hello all,
As I was leaving work yesterday I did my usual 'check for door dings/scratches' walk around and I noticed that someone had keyed my poor mini. :( there is a scratch on the passenger door about 2 feet long. I think it's terrible (I may be bias). I don't think it is through the clean coat, but I'm hesitant on where to start and with what products. I don't want to do detailing with the dealership because the last time I did, it was kind of poor quality.
If anyone can help it would be much appreciated!
If your "work" has closed circuit cameras on the parking lot, I'd be examining them to see whose going to pay to have that fixed for you.
That's just B/S when some "d-head" has to do stuff like that.
+1...Were you parked on the street?
888.280.7799 | 6am - 5pm PST
The neighbor's dog jumped on the drivers door on my MINI and left some scratches in the clear coat. I tried polishing them out with a mild polish but that did no good. I ended up sanding with 1000 grit paper and using polishing compound with a dual action random polisher with a foam pad. It came out real nice and I didn't go through the clearcoat
Dave
Dave
That doesn't look too bad. Generally if you can feel it with your fingernail, it isn't going away, but you can make it virtually disappear. If you can't feel it, you can almost certainly fully remove the scratch.
How familiar are you with polishing?
Blending the door & re-spraying it will be obvious without blending it into other panels unfortunately. But filling and blending should work if you can find just the right shop. GL
99% of body shops will want to paint/blend to repair the scratch. That isn't the worst thing (if they're good), but I'd avoid paint if you can.
I'd find a really good detailer in your area. He (they all seem to be "he") can probably minimize the amount you'll see it, and you may be happy with that.
Aug 10, 2015 01:59 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
