FS:: Front and Rear Shocks w/ Springs
Old Dec 24, 2012 | 03:40 PM
408*'s Avatar
408*
Category: Suspension
Price: $0
Location (Region): South
Fs: Front struts with springs, rear shocks with springs. Came off r56 2012 cooper s jcw. Suspension had 30k miles when removed...taking offers. Willing to ship at buyers expense
thanks!
Old Dec 27, 2012 | 03:29 PM
Oxycooper's Avatar
Oxycooper
PM sent
Old Dec 28, 2012 | 06:25 AM
THE ITCH's Avatar
THE ITCH
Just a note of clairification. JCW springs are always red. You can purchase a JCW car with standard sport suspension which would be black springs.
Which do you have?
Steve
Old Dec 28, 2012 | 04:48 PM
mbwicz's Avatar
mbwicz
You can also get a JCW with the 'base' suspension. I bought a set of struts with springs from a JCW, and the labels said 'Cooper S'. My MCS was ordered with the sport suspension, and the shock labels had 'Sport' on them.
Mike
Old Dec 29, 2012 | 07:35 AM
408*'s Avatar
408*
Struts/shocks are black....bump
Old Dec 29, 2012 | 03:00 PM
k_h_d's Avatar
k_h_d
So to clarify these are not really JCW parts. All JCW cars come with the same base suspension as any MINI would, even a justa. It's really a shame that MINI does this.
Old Dec 29, 2012 | 03:15 PM
408*'s Avatar
408*
Correct, I did not know this. I apologize for the miss post. It's still a sport suspension...so its better than a base model. Thanks guys!
Old Jan 9, 2013 | 07:05 PM
408*'s Avatar
408*
bump
Old Jan 12, 2013 | 06:28 AM
408*'s Avatar
408*
bump
Old Jan 19, 2013 | 07:27 PM
user 72098243's Avatar
user 72098243
If you compare the actual part numbers (sway bars, front struts, rear shocks) between a Cooper S and a factory JCW you'll find the parts are exactly the same with the exception of the front struts. This applies whether it's a Standard or a Sport suspension option, either of which are available from the factory, and both have black springs.
The unknown is the F/R springs. If you look at your spring coils you'll note they are color coded with 2 or 3 dabs of paint, identifying the spring rate engineered for your particular MINI.
Spring rates are calculated based on the weight of your MINI, influenced primarily by heavier options such as transmission (Std./Auto.), Sunroof (Yes/No), etc.
I've not heard of anyone cracking the spring rate color codes but if you've ever driven a JCW and an MCS back to back you'll note the suspensions are clearly not the same.
The special RED spring "JCW Sport Suspension" is an entirely different (and very expensive) option which I believe is dealer installed.
Old Jan 21, 2013 | 04:37 PM
408*'s Avatar
408*
Black springs, black shocks....bump!!
Old Jan 25, 2013 | 03:06 PM
408*'s Avatar
408*
Bump
Old Feb 2, 2013 | 07:25 AM
408*'s Avatar
408*
Bump....offers??
W0TM8
Dec 19, 2019 07:50 AM
emulajavi
Dec 24, 2018 09:15 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
Minibeagle
Aug 13, 2015 10:00 AM
