R50/53 burning rubber smell
I have a burning rubber smell that comes from my engine every time I drive the mini around. It started one or two days ago and I haven't driven the mini since. I'm thinking a belt might be going out? There are no warning lights on. Any insight is appreciated. Thanks
I would also bet on the crank pulley.
You might be able to see the pulley wobble with the engine running.
If you need to take the liner off to get a better look the plastic screws holding the wheel well liner tend to strip-out easy so you might want to purchase some if you have a source near by. If you do not have a source for the screws just be careful. If you only strip one or two everything will go back together OK, with a couple screws, missing until you can get replacement screws.
okay thanks for the advice, the mini is a 2004 s with 95k miles on it, just for a little more info. I have the tire off now I'm taking off the liner tomorrow. I'll let you guys know what I find
If the crank pulley is suspect, will I have to replace both the belt and the pulley itself? Is this what I should be looking at buying?
http://www.amazon.com/Performance-Ha.../dp/B008DYZQ3G
I got the non 2% ATI, as I wanted mine as close to stock. It's actually about .8% bigger in diameter than OEM. Your call on going 2%, the added cost is still cheaper than a charger pulley. Just ask Way if you could still be on stock belt size. Peace of mind is priceless.
Normally you can use the same belt with the +2% ATI, but since you have 95k on the car & have to take the belt off anyway, replace it. Just ask Way or Chad or whomever you get the pulley from to set you up with the appropriate belt also, plus, may be worth looking into renting the puller & install tool from them also, if you're going to do it yourself.
The 2% will spin the supercharger a little faster which will increase the boost by about 0.5 to 1 psi thus increasing your horsepower slightly.
I went with the 2% pulley. I have a JCW S/C pulley with the 2% crank and used the JCW belt size. I believe stock size belt will work with 2% but you can double check with whomever you purchase the pulley from.
I suggest that you replace the belt.
You should also replace the crank bolt.
http://www.waymotorworks.com/super-d...ulley-r53.html
You will need to buy/borrow a belt removal tool.
http://www.waymotorworks.com/cooper-...-tool-r53.html
You will need a pulley puller tool similar to (I got mine from harbor freight for $15).
http://www.waymotorworks.com/crank-p...l-r52-r53.html
After getting the wheel and well liner off I got a good look at the pulley and after running it for a little bit i got the smell and I noticed movement on the pulley. I have a mechanic friend who's going to come over during the weekend to help me change the pulley and belt out. I'll keep you guys updated
I saw the special tools required and I will have them, thanks though
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
