Interior/Exterior Paint Correction Question(Joey Mod)
Old Dec 15, 2012 | 08:21 PM
IzzyG's Avatar
IzzyG
So I just finished spraying for the joey mod and noticed that there's a run in one of the headlights. Argh! It's a quick drying engine paint(high temp paint). Instructions says to shoot multiple layers but within one hour(10 mins in between so I felt slightly rushed)
So 2 options:
1. Ignore the run (it's not THAT obvious but unsure if it will stay that way with headlights on(or even off once headlight is put together)
2. Fix it. But do I have to wait till the paint cures before sanding it down?(7 days according to instructions on can but I can't have the car OOC for 7 days) ;/ Or just sand after 12 hours and go at it?
Old Dec 15, 2012 | 08:23 PM
IzzyG's Avatar
IzzyG
Just to add: The run is about 4 inches long BUT it's not a large difference in depth(so not that obvious).
Old Dec 17, 2012 | 09:03 AM
quikmni's Avatar
quikmni
Since you posted about the run I suspect it is really bothering you, I know it would bother me. You know it is there and it will bother you forever even if not obvious. You should fix it now.
My thoughts are:
Try sanding with very fine wet/dry sandpaper, with the paper wet.
If the paint is still too soft to sand with wet paper, you could bake the assembly in a low heat over to cure the paint a little quicker. Make sure the paint is back to room temp before sanding again.
Old Dec 17, 2012 | 02:00 PM
ammodave's Avatar
ammodave
I've used high temp paint for other purposes (not Joey mod) and it's always more durable if you bake it. I don't know how much heat a headlight surround can stand but I've baked lots of plastic parts at 170-180 degrees with no problems. I'd bake it for a couple of hours and then gently level out the run with 600 grit wet/dry sandpaper. Lightly scuff the rest of the surface to insure adhesion and then respray.
Old Dec 17, 2012 | 05:36 PM
Malcon's Avatar
Malcon
at least let it dry overnight. If you sand it with it wet there is a chance it will gum up on you and make an even worse situation.
Good luck!
sevin
May 2, 2026 06:11 AM
W0TM8
Dec 19, 2019 07:50 AM
2011cooperSconvertible
R57 :: Cabrio Talk (2009+)
Apr 1, 2019 06:03 AM
Bennyboy
Aug 18, 2015 07:28 AM
Minibeagle
Aug 13, 2015 10:00 AM
