R56 Has anyone tried to run Alta Acessport Stage 2
stage one only on a stock R56 jcw exhaust
tons of threads on this
Yep, makes no diff, yours( and mine ) exhaust is too stuffed up . I don't think the 2nd stage tune thing is gonna matter too much anyways. You would have to run a loud, and/or code throwing exhaust to use the #2
there you go..... change some of the JCW exhaust( the cat) and you will be OK, thanks for the info
( how much diff are you seeing with the stage two?)
Just wanted to put a disclaimer on this.. Although this is what i'm running right now, this was against ALTA's recommendations. Per Alta, i should stick to stage 1 fmic regardless if i have an aftermarket dp unless i have a 2.5" or bigger exhaust system. With the jcw being to about 2.25", i figured its worth a shot.
From a difference perspective, big pull difference but nothing like you get wet in your pants.
Hope this helps.
Hope this helps.
Aug 21, 2015 11:25 AM
