R55 best springs to stiffen the suspension without lowering?
Old Dec 13, 2012 | 04:21 PM
veloci1's Avatar
veloci1
i'd like to have my suspension a little stiffer, but, i do not want to lower my Clubman.
is that possible? if so, what is the best set up? Koni and ????
Old Dec 13, 2012 | 04:30 PM
cristo's Avatar
cristo
Alliance Member
How about Bilstein SP shocks and either stock springs or JCW springs (stiffer, minimal drop - and the Bilsteins' gas
charge may recoup a little of the 10 mm drop).
(... that is, if they make jcw springs for the Clubman -I forget if they do)
Old Dec 13, 2012 | 05:50 PM
davisflyer's Avatar
davisflyer
Swift Spec-R springs
Old Dec 13, 2012 | 08:33 PM
veloci1's Avatar
veloci1
I was told that Swift does make springs for the Clubman. Also, the JCW springs are supposed to be a little too stiff.
After reading a few posts, it seems that changing my rear sway bar to the sport Hotchkis 25 hollow would help improve the handling of my car without giving up ride comfort.
My clubman is my DD and I just want better control over all/ less body roll.
I like to zip through the streets of Los Angeles on my way home. Weekends, I just driving fast up in the mountains.
Old Dec 14, 2012 | 06:05 AM
cristo's Avatar
cristo
Alliance Member
I read that Swift does not make springs for the Clubman.
See copy of recent post below.
__________________________________________________ ______
"09-10-2012, 01:47 PM
TrackWorx
Vendor
Feedback Score: 0 reviews
Gallery
Quote:
Originally Posted by jbobp
Price for an R55, please.
Swift does not make a lowering spring for the clubman.
Sales@TrackWorxTech.com
Swift R-Spec Springs R53 and R56
https://www.northamericanmotoring.com...wait-time.html"
__________________________________________________ ___________
The stock springs are the only springs I know of that don't lower any.
That's why I recommended staying oem for springs along with a stiffer shock
like the Bilstein Sport. Could also use Koni Yellow (Sport) with the stiffness
cranked up most of the way (but not all of the way - not recommended
for longevity reasons).
Might also consider the Bilstein HD shocks. For some models the Sport and HD
have the same valving (i.e. VW) but the Sports have internal dimensions designed for
lower springs, and for some models the Sports are have stiffer valving than the HD
and Sports better for lower springs. Not sure if the MINI applications have
the same or different valving for Sport vs. HD.
The Hotchkis 25 mm hollow rear bar set on the softer setting sounds like a great idea.
Old Dec 14, 2012 | 12:31 PM
bhegg's Avatar
bhegg
I don't know if they have them for a Clubman, but the TSW springs that I had on my MCS did not seem to lower my car "that much" from stock ride height. I didn't measure before and after, but the wheelwell gap still looked close to stock. It appears that my current Swift Spec-R springs are a little lower than the TSW springs that were installed.
Old Dec 17, 2012 | 01:52 PM
veloci1's Avatar
veloci1
should i install the TSW X-Brace before the Sway bar?
just wondering after reading how the brace improves handling and reduces steer torque.
Old Dec 17, 2012 | 05:56 PM
Eddie07S's Avatar
Eddie07S
The MINI sports suspension springs are stock height and a bit stiffer than the stock springs. If you don't want to lower the car, that is your best option. As long as you are taking the suspension apart, a set of Bilstein sports is a good suggestion.
IMHO the 2 best MODs to improve the "zip" around town are a set of IE fixed camber plates and a 19mm rear sway bar and leave the springs alone.
The 25 mm RSB is way too much for the street. Search the posts for the people who put in a really big RSB and unfortunately swapped ends on a wet on/off ramp. The 19 mm would be a great improvement and won't get you into trouble.
Old Dec 17, 2012 | 06:02 PM
Albiecrazy's Avatar
Albiecrazy
Originally Posted by eddie07s
the 25 mm rsb is way too much for the street. Search the posts for the people who put in a really big rsb and unfortunately swapped ends on a wet on/off ramp. The 19 mm would be a great improvement and won't get you into trouble.
+1
Old Dec 24, 2012 | 02:16 PM
veloci1's Avatar
veloci1
Ok, I have decided to go with the tsw brace and 19 mm sway bar. It seems like these two add ons will get me what I am looking for.
I will keep you posted once they are installed.
Thank you for all the responses.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
melscoop
Mar 30, 2016 06:56 PM
loop4re7
Oct 5, 2015 09:53 PM
G1HQ
Aug 28, 2015 01:41 PM
Emnotek
Aug 13, 2015 05:47 PM
