Temperature sensor "recall" - cold start on hot day
Old Dec 11, 2012 | 02:11 PM
pw4's Avatar
pw4
My 2010 R56 LCI MCS is suddenly having problems with a cold start on a hot day (in the 90s Farenheit). The dealer says this is a known issue and a faulty temperature sensor is the subject of a replacement program by MINI.
The engine starts but just chugs as if it's about to stall. Sometimes it comes good, sometimes it needs several attempts then it fires (in a cloud of grey smoke). No warning lights or message. This apparently is the typical set of symptoms.
Even with the turbo fan that was a recall in other countries, MINI here in Australia just rolled it out through normal servicing or on request . They're doing likewise with the temperature sensor so it might be a recall elsewhere; if not, it's worth requesting the replacement if you're somewhere with hot weather.
And MINI Australia has run out of the replacement part so mine's on order from Germany - hopefully getting here before I head off to hot inland areas over Christmas!!
Old Dec 15, 2012 | 06:49 PM
walk0080's Avatar
walk0080
Old Dec 16, 2012 | 03:21 AM
pw4's Avatar
pw4
Thanks. My starting problem is only for cold starts (ie first start of the day) on a hot day, but I get the hesitation and slow warm-up you mention.
Thanks for the info - it's encouraging to know the fix really works.
iggi
18
Feb 9, 2026 01:00 AM
Kimolaoha
Jul 5, 2023 01:04 PM
Melvinyip
Apr 17, 2020 09:28 AM
TREX
Nov 2, 2019 07:31 PM
PSIChocolate
Aug 13, 2015 12:46 PM
