R50/53 Trifecta festival of lights after a brake job
Old Dec 8, 2012 | 08:18 PM
quickslvr580's Avatar
quickslvr580
So... I did my front brakes (rotors/pads) & rear pads. I did solder the two wires on together on both brake sensors and that caused the wear sensor light to turn off properly.
I broke the brakes in a little before I headed out to see some friends. I drove a total of 50 miles and then all of a sudden the DSC light flashes and starts cutting power and then the ABS & Tire Pressure light come on.
I know it could be a wheel speed sensor from other posts I've read, but I didn't touch any of them during the process.
Do you think by me just soldering the wear sensors affected anything?
I swear Mini's are just too sensor happy.
Thanks for the help.
Signed-
Frustrated
Old Dec 8, 2012 | 08:58 PM
submitaweasel's Avatar
submitaweasel
Maybe relevant maybe not: my FR ABS line ended up coming loose and contacting the crank pulley...which wore through the line and ended up shorting the line causing the same trifecta.
Old Dec 8, 2012 | 09:34 PM
quickslvr580
I was on my home at it was dark out so I couldn't check anything. I am going to pop under the wheel wells and see if I can locate any compromised wires/ sensors.
If none of them aren't compromised i'll clean the sensors and use some dielectric grease on them and see how that works.
Old Dec 9, 2012 | 05:50 AM
Capt_bj's Avatar
Capt_bj
sounds like a damaged wheel speed sensor
this is telling ABS system there is a problem and tire system one is low . . .
easy to fix is the good news
bad news is unless you can SEE a problem sensor, you need MINI specific diagnostics to ID which one is the problem
sevin
May 2, 2026 06:11 AM
theblackfalcon
Oct 11, 2015 09:49 AM
thebordella
Aug 31, 2015 01:37 PM
