Suspension Do I really need an alignment?
Old Nov 26, 2012 | 12:43 PM
JAB 67's Avatar
JAB 67
I'm having an argument with my independent MINI-centric mechanic. He replaced my LCA bushings with OE at about 75K and did not push me to get an alignment. Now at 121K the OE are shot again, and I'm going with Powerflex. My mechanic insists on selling me an alignment, simply because of the bushing change, not any uneven tire wear, etc. Cash is in short supply. Who is right here? TIA.
Old Nov 26, 2012 | 08:07 PM
JAB 67's Avatar
JAB 67
bump
Old Nov 27, 2012 | 03:12 AM
N2MINI's Avatar
N2MINI
My thinking is an alignment once a year is a good thing, and I would take it somewhere else to have it done just for the cost of it.. My dealer probably wants aound $100 or so, and I can get it done for $65, less then a mile away, and they will let me give them the settings I want it set too...
Old Nov 27, 2012 | 04:11 AM
slinger688's Avatar
slinger688
You should get an alignment after changing the bushings. If something in the susprnsion has changed during the install, you can have poor tire wear which is likely more expensive to replace. I find that sometimes alignments can also improve the fuel economy of my car.
Old Nov 27, 2012 | 05:58 AM
cristo's Avatar
cristo
Alliance Member
Front toe-in settings wander a bit with worn bushings as the wheels can move to and fro
a little and it's hard to get a consistent reading, but they are very stable after
replacing the bushings. I'd check front toe afterwards to make sure it's correct as too
much/little will greatly increase tire wear and change straight ahead stability.
Camber can shift with this work if the subframe isn't put back exactly where it was
initially, although I don't think there's enough side-to-side leeway to make much of
a difference most of the time. I've had this done twice without an alignment, and the
camber was exactly the same after as before. Checking the front camber wouldn't hurt,
though.
The caster shouldn't change and neither should the rear wheel alignment unless they
drop the MINI off of the lift.
Old Nov 27, 2012 | 07:42 AM
ViperNL's Avatar
ViperNL
You should check if you have a Firestone nearby, they sell a (car) lifetime alignment for 170 I think. Seemed like a good deal to me
Old Nov 27, 2012 | 02:44 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
+1 for the Firestone deal. Also many dealerships usually have a monthly or weekly deal going on ($69.99 at South Bay BMW not too long ago). I've also heard an alignment is recommended whenever suspension components are replaced (even bushings - not quite sure how necessary this is though).
888.280.7799 | 6am - 5pm PST
Old Nov 27, 2012 | 03:42 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Call around to see who offers a lifetime alignment deal, not all shops will take a lowered MINI.
Alignment about once a year is helpful to allow for best tire wear and handling. About $90-120 is common with specialty shops and some chain shops will run specials and charge less to draw in customers.
OEM bushings that wear out in 50,000 miles? That's a little early but on rough roads it is possible. Powerflex bushings are stiffer and better for handling and performance but might wear even faster. Try checking with Way at Way Motor works and see what he says for your situation.
Look for other worn out suspension parts and see if there is anything else contributing to your problem.
Old Nov 27, 2012 | 04:36 PM
cristo's Avatar
cristo
Alliance Member
My OEM bushings wore out in about 30K on our rough PA roads.
My second set of OEM's wore out in another 30K.
Now I have Powerflex ones, and the word I've heard is that they last several times longer than OEM.
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
Keet
Suspension
Aug 30, 2016 03:46 PM
wildwestrider
11
Jan 29, 2016 05:06 PM
daviday
Sep 25, 2015 01:31 AM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
