Brakes
Old Apr 3, 2004 | 04:52 AM
mini5's Avatar
mini5
I have used ROTEX brake pads on previouse cars (Miata and Passat). Their claim to fame is using KEVLAR, so not only are they dust free, but they are bullet proof as well. Does anyone have experience with ROTEX pads on a MINI?
Old Apr 3, 2004 | 05:00 AM
d-mini-ero's Avatar
d-mini-ero
I originally started w/ the orig factory pads....
I've gone thru a set of EBC pads... which reduced the brake dust.
I just had a set of the orig factory pad and new facotry rotors put on my MCS @ approx 34K.... as they are still FREE
Old Apr 4, 2004 | 08:27 AM
Chayse's Avatar
Chayse
D,
Are brake pads and rotors covered under the maintenance package from MINI? I just found out that my inner rear brake pads are worn down to the backing plates and rubbing on the rotors. it is only the inner pad though not the outer one that you can see from looking through the wheel.
Thanks.
Old Apr 5, 2004 | 06:45 AM
polmear's Avatar
polmear
>>D,
>>Thanks.
Chayse,
You have faulty calipers, they should be replaced under warranty. Inner pads should NEVER wear out that much before the outers. Have the rotors checked for excessive wear as well, everything should be replaceable under warranty-depending on your mileage.
Old Apr 5, 2004 | 08:24 AM
Chayse's Avatar
Chayse
Yea, Called the SA this morning. He said to bring it in. He also said that Rotors and pads are covered under the free maintenance MINI has. I sprung for the extra year too. Taking it in Wednesday. Taking it easy till then.
Thanks.
Old Apr 5, 2004 | 08:34 AM
sanddan's Avatar
sanddan
D
You were lucky, my dealer refused to replace warped front rotors (at 24K miles) because I installed EBC green pads to reduce dust. I just upgraded to powerslots instead.
Dan
Tires, Wheels & Brakes
Sep 10, 2015 12:27 PM
Sep 10, 2015 10:52 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Sep 3, 2015 03:22 PM
