R50/53 Transmission to oil pan torque?
Old Nov 24, 2012 | 05:07 AM
ericscottf's Avatar
ericscottf
Hello all,
I am replacing my oil pan and can't find the torque for the 3 bolts that go between the transmission and the oil pan. None of the guides or my bentley manual specify.
Does anyone have it? They're 3 M12x1.75 bolts 65mm long.
I should mention, this instruction manual:
http://r53minicooper.wordpress.com/2...s-r53-part-11/
says:Tightening torque 21 11 1AZ
But i don't know what that means...
According to this:
http://tis.spaghetticoder.org/s/view.pl?1/07/69/24
It is 85 n-m if you click on the link at the bottom. But the link leads to a list for 23 00
Can someone confirm?
Fun incident: The last dealer that worked on my car rounded off one of the bolts pretty badly *while taking it off* and then re-used it! I --barely-- got it off, so now i'm searching for a replacement. none of the local auto parts stores have it, so I got a so-so bolt from home depot that i'll use to drive to the dealer.
thanks!
Old Nov 24, 2012 | 05:18 AM
cristo's Avatar
cristo
Alliance Member
On my TIS cdrom, which only goes up to 2003, the Midland (R50) and the Getrag (R53), both say 85 Nm,
which is 62.7 ft-lb, for the three transmission to oil sump M12 bolts.
I can't imagine the 5-speed Getrag on the 2005 MINI R52 (justa)Cooper Convertible would be any different.
Old Nov 24, 2012 | 05:29 AM
ericscottf's Avatar
ericscottf
That was amazingly fast. Thank you so much!
Old Nov 24, 2012 | 06:18 AM
cristo's Avatar
cristo
Alliance Member
Yer welcome. Easy to look up when I'm at home.
Etrain
16
Aug 5, 2024 04:37 AM
SheldonCooperS
Aug 25, 2015 11:57 AM
ShadyCoop
Aug 24, 2015 06:05 AM
Lex2008
Aug 16, 2015 08:33 PM
minipopkart
Aug 13, 2015 05:22 AM
