R50/53 What are the cylinder head differences s vs. justa
Old Nov 22, 2012 | 12:56 PM
Braminator's Avatar
Braminator
What are the differences. Is there a way to tell them apart.
Old Nov 22, 2012 | 01:12 PM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
They are the EXACT SAME HEAD! There is no differances between them, even the cam is the exact same.
The JCW head was barely cleaned up by the factory... Ported just enough to get rid of the casting marks on the intake side and a VERRY mild port done to the exhaust side. NO change in the valve size, or angle either. Pretty dissappointing, I know.
Old Nov 22, 2012 | 01:13 PM
ACallahan's Avatar
ACallahan
The valves are different on the S head because of hotter temps generated
Old Nov 22, 2012 | 01:38 PM
cristo's Avatar
cristo
Alliance Member
+1 true
same dimensions but different material valves on the S head.
otherwise heads are exactly the same between the R50 and R53.
Old Nov 22, 2012 | 02:38 PM
JumpingJackFlash's Avatar
JumpingJackFlash
Pulling info from the MINI Bentley Manual, it indicates the valves are made in a Cooper S head are made from an improved material. This thread indicates the exhaust valves contain Inconel: http://www.mini2.com/forum/first-gen...nder-head.html. All heads have a three-angle valve job from the factory. Valves in both non-S and S heads are the same size. I don't know personally, but several threads on NAM quote the JCW head as having a 4mm increase in the exhaust port size; unsure on any additional port work.
Manny_cooper
17
Nov 1, 2024 07:46 PM
Teh
Aug 22, 2022 04:37 AM
Kimolaoha
Dec 5, 2020 09:32 PM
bobbiemartin
Jan 20, 2016 05:28 PM
MIminiclubman
Aug 5, 2015 09:14 PM
