Oil Leak
Old Nov 21, 2012 | 09:26 PM
cheapdanny's Avatar
cheapdanny
Oil Leak
I've searched and searched but need some help identifying this hose with an oil leak. Thanks.
Attached Thumbnails Oil Leak-hose-1.jpg   Oil Leak-hose-2.jpg   Oil Leak-hose-3.jpg
Old Nov 22, 2012 | 06:30 AM
jcauseyfd's Avatar
jcauseyfd
My guess would be your chain tensioner has backed out a bit and is leaking. The oil on the hose is just where it is getting sprayed.
Old Nov 22, 2012 | 06:32 AM
bluefox280's Avatar
bluefox280
That's the 'cold-side' boost tube, which is apart of the intake system.
That oil seepage is typically from the oil vapor pulled in from the Positive Crankcase Ventilation (PCV) system.
Simply remove, clean and reassemble.
While removed, check to see how much oil film is inside... will that much seepage, I'll be curious how much oil is possibly collected in the intercooler.
* http://realoem.com/bmw/showparts.do?...06&hg=13&fg=20
- Erik
Old Nov 22, 2012 | 07:01 AM
cheapdanny's Avatar
cheapdanny
Thank you Bluefox! Will update later with pictures as I take apart and clean.
Old Nov 22, 2012 | 09:28 AM
bluefox280's Avatar
bluefox280
You're welcome and good luck. Please do take some pics and we'll be able to give you some insight on how much oil seepage is too much or not.
- Erik
Old Nov 24, 2012 | 06:51 AM
cheapdanny's Avatar
cheapdanny
Thanks jcauseyfd, I looked all over and only see oil residue on the hose. I did take apart the cold side boost tube as bluefox280 suggested and found a broken rubber gasket/o-ring. As I took it apart, I did find oil on the top half as you can see in the pictures. The question is whether this is a lot?
Attached Thumbnails Oil Leak-img_2560.jpg   Oil Leak-img_2562.jpg   Oil Leak-img_2563.jpg
Old Nov 24, 2012 | 06:55 AM
bluefox280's Avatar
bluefox280
That explains the seepage issue; when you make positive boost, the pressure is pushing the oil film out of the intake seals.
No, that's typically a normal "film" amount. A small collection pool can occur, but I don't see anything out of the ordinary.
Good news, with that replaced O-ring, you should have better holding boost pressure which will return some performance to the car.
- Erik
Old Aug 29, 2013 | 12:51 PM
jer361's Avatar
jer361
Any one know the part number for that O-ring? Mine is leaking from the same place and you can smell oil burning sometimes under boost. I'm going to take it apart to check but would like to have the part first.
woodstudio
Mar 15, 2020 08:28 AM
SheldonCooperS
Aug 25, 2015 11:57 AM
ShadyCoop
Aug 24, 2015 06:05 AM
Laura Redd Casler
Aug 15, 2015 09:32 PM
azntaiji
Aug 13, 2015 03:24 PM
