R56 Strange Noise (Popping) or Thump
Old Nov 21, 2012 | 05:07 AM
PParker74's Avatar
PParker74
Hi all, was wonder if anyone has ever experienced this noise in their Mini? I hear this weird popping or thump noise when stopped I can even feel it in the bottom of my seat. It's located in the center more toward the rear. I doesn't seem to affect the drive ability. I also hear it when I park in the garage and turn the car off. It doesn't really bother me but just want to make sure if something is wrong that I fix it before something happens. The noise doesn't start until the car gets warm... Thank you in advance for your help.
Old Nov 21, 2012 | 05:45 AM
submitaweasel's Avatar
submitaweasel
Take a video? Exhaust could be hitting something maybe? Could be any number of things. A video would be your best option for a diagnosis.
Old Dec 28, 2012 | 01:13 PM
myR56S's Avatar
myR56S
So I was bored at work and was snooping through some older posts and noticed this one.
I too have experienced this as I stop, pull the e-brake, turn off the car. Then shortly following the car makes some odd thumping noises. I too started wondering what that was. I was parked in my garage and let the car remain in gear and released the e-brake. No noise. I believe it is slight movement that is created when the pads move ever so slightly against the rotor. Move how you ask? The brakes are cooling/heating from your drive and they will expand and contract which causes movement.
If you have already found your solution sorry for the long reply...
Old Dec 29, 2012 | 08:40 AM
Spridget's Avatar
Spridget
You can also get mysterious thumping noises from the fuel tank, as pressure equalizes. I've only heard the thumps a couple of times in my own MINI, but others have reported the same sounds.
Spridget
Old Dec 29, 2012 | 09:02 AM
MandB's Avatar
MandB
DMTL is potential source of noise...
Hey, PParker,
Following up on Spridget, I too had this noise occur a few weeks ago and was able to narrow down the issue by searching for "MINI fart noise" of all things!
Once I started to dig a little deeper and consulted my Bentley Publishers MINI Service Manual, I found a part called the DMTL which resides in the fuel tank and acts as a pressurization mechanism for detecting system leaks. It is possible that temperature changes and/or short duration drives facilitate some residual activity from this pump. It sounded like a series of "poofs" coming from under the back wheel well. Satisfied and confirmed that it's nothing to worry about.
Hope this helps if it is in fact the source of your mystery noise.
Old Dec 29, 2012 | 09:17 AM
k_h_d's Avatar
k_h_d
What MandB is talking about is likely what you are hearing. In my 2003 I could here that noise as well and I guess possibly even feel the slight vibrations... It did not do it all the time but there was an article I read in a magazine about it as well. From what I remember it was nothing to be concerned about.
Old Feb 11, 2013 | 05:11 PM
NJ Mini's Avatar
NJ Mini
This got me too! Thought my MINI had a flatulence issue.
Glad this thread cleared that up. Thought I had another item on the list for the next dealer visit.
Old Feb 11, 2013 | 08:27 PM
RJKimbell's Avatar
RJKimbell
It's a Trunk Monkey...that's all!!
BernieCoop
Sep 10, 2021 03:15 AM
dinomaniac
Sep 18, 2018 04:19 AM
Supertractor3
Apr 7, 2017 11:16 AM
rob&JCW
Oct 9, 2015 11:12 AM
jarymo
Hawaii MINI Motoring Club
Sep 30, 2015 04:19 PM
