R50/53 Soft clutch pedal issue
Old Nov 19, 2012 | 08:04 AM
tiny s's Avatar
tiny s
Hey guys, just put in a Valeo clutch kit with the single mass flywheel and now the clutch is really soft. It engages but its super soft. It engages close to the floor to. Any ideas what would cause this? Thanks
Old Nov 19, 2012 | 08:16 AM
cristo's Avatar
cristo
Alliance Member
Maybe the clutch needs to be bled (easier said than done -do a search on this).
Old Nov 19, 2012 | 02:08 PM
tiny s's Avatar
tiny s
stuff
Also have alot of noise coming from it. Doesnt seem as powerful as it used to be.
Old Dec 9, 2012 | 05:23 AM
Nick5811's Avatar
Nick5811
Subbed. I think I have the same thing, minus the noise. I seem to have about an inch or two of play in the pedal, and it takes less pressure to push in. Quicker stronger engagement for me though.
Old Dec 9, 2012 | 05:41 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
You want the clutch to grab early...typically grabbing late is when you have a problem.
Take a stick, place it between the bottom seat and your clutch pedal while it's against the floor. Leave it that way overnight. See if maybe that gets some of the bubbles out of the system.
Old Dec 10, 2012 | 05:26 AM
tiny s's Avatar
tiny s
stuff
Update: clutch has gotten a bit more stiffer. It still sounds like a old *** jeep though. I ordered a new slave cylinder so will see if this helps at all.
eliseo1981
Jan 28, 2021 02:45 PM
DiGiPiMP
Aug 24, 2015 11:04 AM
Powershift
Aug 16, 2015 05:14 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
oldsbear
Eastern Iowa MINIs
Aug 9, 2015 04:02 PM
