R56 Oil diaphragm/vacuum leak
Old Nov 16, 2012 | 06:23 PM
Rwynne's Avatar
Rwynne
After driving home from having my thermostat housing replaced,my check engine light came on.Thinking maybe a vacuum line was loose,I returned to have my mechanic check it out.After checking hoses,fittings,etc,he opened the oil filler cap(it was hard to remove)and immediately said it was a diaphragm in the valve cover area that he estimated would cost $500.00 to repair.This sounds bizarre to me,or is it just another strange mini problem?
Thanking all input in advance.....
2007 R56 S
Old Nov 16, 2012 | 09:16 PM
bluefox280's Avatar
bluefox280
If the internal positive crankcase ventilation (PCV) valve is seized shut, you could have a internal vacuum issue.
See the lower part of page one and read up on the valving that's apart of the valve cover:
* https://www.northamericanmotoring.co...-and-more.html
- Erik
Etrain
16
Aug 5, 2024 04:37 AM
woodstudio
Mar 15, 2020 08:28 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
SheldonCooperS
Aug 25, 2015 11:57 AM
Laura Redd Casler
Aug 15, 2015 09:32 PM
