R50/53 R53 Hesitation after reduction pulley install
Old Nov 14, 2012 | 02:28 PM
junior's Avatar
junior
Just installed a 15% reduction pulley (& smaller belt) to my 05 R53, including a set of NGK BKR7EQUP plugs and have noticed a hesitation, feels like a single misfire just before 3000 RPM & about 8 PSI boost, any ideas? Wasn't apparent before the pulley upgrade. No trouble codes according to my UltraGauge.
Old Nov 15, 2012 | 11:09 AM
Geaux4Breauxk's Avatar
Geaux4Breauxk
How many and how much of the holes can you see on your belt tensioner?
Did you install the pulley correctly and tighten it down all the way per the manufactures instruction?
Is the belt installed over the pulleys in the right order? Even if you have the correct size belt, the wrong order can cause the belt to slip on the SC.
Teh
Aug 22, 2022 04:37 AM
blackie
Jan 18, 2017 09:56 PM
squawSkiBum
Oct 2, 2015 09:21 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
