R50/53 Clanking up front again????
Old Nov 13, 2012 | 06:43 PM
tiny s's Avatar
tiny s
So I have replaced pretty much everything up front. Upper strut mounts, upper/lower ball joints done about a year ago. Struts, sway bar connecting rods, outer tie rods about 5 months ago and most recently wishbone bushings from Powerflex. But again the front end sounds as if the wheels are going to break off. Any other ideas?
Old Nov 13, 2012 | 08:40 PM
Kahnfucious's Avatar
Kahnfucious
Did you replace the often worn out A-arm bushings? How many miles on the car?
Old Nov 13, 2012 | 08:45 PM
tiny s's Avatar
tiny s
stuff
Yeah, that's what i meant, the a arm bushings. There's 134k on the car.
Old Nov 14, 2012 | 01:11 AM
Noir2005's Avatar
Noir2005
Sounds, or feels? Cause that's two different things. With poly bushings, your going to hear sounds louder with the suspension, then with stock bushings, thus why most bushings on cars are neoprene, and not poly. So if you had a bad bushing(s) you probably didn't change the sound. If it feels like the tires want to come off, then that s a different story.
The suspension on these things are a little stiff out of the box, so putting larger rims/ run flats, and or springs and struts will certainly give you a teeth rattling sound that your front tires would of sheared off on that last bump.
What mods have been performed on the car prior to this sound? Springs/struts upgrades? Larger rims? Also, I've seen it many of times, just cause something is new, doesn't mean it's fine out of the box, and with stuff that's a year old, there is a chance they may have gone bad in that time.
Old Nov 14, 2012 | 05:41 AM
tiny s's Avatar
tiny s
stuff
Like a metal to metal clanking sound while driving at more or less slower speeds. Say between 1 and 40 mph but is still noticeable after just less. No real suspension upgrades except the control arm powerflex bushings which made it quiet again for a short while. Wheels are 17".
Old Nov 14, 2012 | 05:43 AM
Kahnfucious
So from your other post -- your wheel is doing this?
That video explains what a worn hub bearing looks like
Old Nov 14, 2012 | 05:44 AM
ZippyNH's Avatar
ZippyNH
If it is a 2005+, with the oil filled to motor mount, it can clunk when it fails....older ones are a different desgin, but can still wear, espically with lots of miles
Old Nov 14, 2012 | 06:43 AM
tiny s's Avatar
tiny s
stuff
The wheel only moves a bit side to side but not from top to bottom. Didn't think about the pass side motor mount. I have inserts on the tranny mount and bottom rear mount. When standing on the frame with the hood open and bouncing the car up and down I can't get the clanking sound.
Old Nov 14, 2012 | 06:53 AM
Kahnfucious
I don't think it shouldn't move at all -- so something is not right...when you say Side to side do you mean forward and back towards the body of the car? Failing Axle or CV Joint?
I am assuming you are torquing wheel bolts on appropriately, that you are using Hub Centric rings for the wheels, that the wheels are not damaged in anyway.
Powerflex A-Arm bushings if installed properly should be good for the life of the vehicle...so..
I would very carefully go through all the items again, double checking torque specs of the ball joints, sway bar etc..
Sorry -- do keep us updated though.
Old Nov 14, 2012 | 12:08 PM
Noir2005's Avatar
Noir2005
Do this to check you engine mount. Have it in park, or put it in 4th or 5th gear so it doesn't roll away lol. Open the hood and push the car back and forth and watch the mount and engine, if you get your metal sound, or the engine is swaying way too much and so is the mount, bingo. Also see if there is oil residue under the mount. They are hydraulic, and are filled with glycol, so when they split, they spill all o er that area.
Mini7
Feb 2, 2016 07:52 PM
Aug 19, 2015 12:51 PM
FLYM1N1
Aug 15, 2015 11:20 AM
Minibeagle
Aug 13, 2015 10:00 AM
