R56 iPod Input Sound Quality??
Old Nov 2, 2012 | 04:17 AM
AYEBOY's Avatar
AYEBOY
I've found that when I connect my iPod/iPhone to the car, there is a lot of distortion in the audio compared to regular radio. I've also tried the cable from my 3 series, so I know it's not a cable issue. Anyone with a similar experience?
Old Nov 2, 2012 | 04:47 AM
dustint's Avatar
dustint
Have you adjusted the input volume? That could easily be the cause. Check the manual for the procedure, it's very easy.
Old Nov 2, 2012 | 11:36 AM
ra2fanatic's Avatar
ra2fanatic
It is the cable, it's just as finicky as when I had my 335i. Wiggling the y-cable and what not will probably solve the problem.
Old Nov 2, 2012 | 12:01 PM
Scooter09's Avatar
Scooter09
I found that if I put the EQ on the iPod to base reducer it gets rid of the distorition. Whatever you have the EQ set to on the iPod is doubled by the EQ on the stock stereo.
Old Nov 2, 2012 | 01:07 PM
Capt_bj's Avatar
Capt_bj
after trying a couple of different cables I ended up spending about 30 minutes trying different combinations of high/low of the input versus the Ipod and eventually got things to work.
My aux-vol is set to 4 on the scale of 1 to 6 .... I have the standard radio .... then I played with Ipod vol vs radio volume at the vol ****
I don't actualy use an Ipod much in the car but use a NANO when I do. A friend uses hos all the time and was the one who convinced me it really could work!
Old Nov 2, 2012 | 06:49 PM
thunderball kaboom's Avatar
thunderball kaboom
For me, it was the phone causing the feedback. Search amazon for a fiiO L10 20- inch iPhone/iPod adapter that plugs into the aux port via the dock connector rather then the earphone plug. About $15. Better sound than the earphone port and no distortion.
Old Nov 3, 2012 | 05:36 AM
Subzero's Avatar
Subzero
I agree, I have the same cable from Amazon and it's great! The line-level output from the dock connector is so much cleaner, plus no fooling with the volume, just plug in and go!
Old Nov 3, 2012 | 02:02 PM
AYEBOY's Avatar
AYEBOY
Will check back and report... thanks!
definitely not the cable. Tried both from my 335 and MCS, but they work fine in the 335. Thanks though!
will try this too! Thanks!
I'll keep this in mind. Thanks!
If all of the above fails, I'll know what to do. Thanks for the suggestion!
Old Nov 3, 2012 | 02:29 PM
Capt_bj's Avatar
Capt_bj
The fancy Ipod special cable is probably the way to go if you plan to use this much, but for me, a NANO does not have a docking connection and like I said I don't use it much so I'm NOT going to upgrade my MP for the car.
but I'd note that I can plug my NANO into either of my Honda's factory AUX port with the same cable (or my KIA or my Nissan) and everything sounds fine . . . . b4 any hunting for the ONE combination of settings that works
I only mention this since we suspect/wish MINI corporate reads stuff here as a source of customer feedback
Branto
Aug 11, 2017 05:32 PM
khumpert
Nov 30, 2015 11:48 AM
Chippawaguy
Electrical
Nov 8, 2015 08:27 PM
dpcompt
Aug 12, 2015 07:39 PM
