R56 07 justa shakes at idle
Old Oct 27, 2012 | 07:48 PM
yyj3869's Avatar
yyj3869
This is taken right after oil change, before oil change it was more rough. the symptom is that when i step on the brake on red light and fully stopped the car, the whole car body shakes wid rpm going down to 500. I went to ask dealership yesterday without appointment. they suspect that it might be throttle problem but not sure about it. please help me out guys.
https://www.youtube.com/watch?v=kklS...e_gdata_player
Old Oct 27, 2012 | 08:18 PM
R56BrgMcs's Avatar
R56BrgMcs
May be something with the transmission?
Old Oct 28, 2012 | 10:45 AM
yyj3869's Avatar
yyj3869
you mean it needs transmission fluid?
Old Oct 28, 2012 | 10:59 AM
Porthos's Avatar
Porthos
I am going to lean on check the mounts to see if they are wore out. What year is it again.
Old Oct 28, 2012 | 12:19 PM
yyj3869's Avatar
yyj3869
it's 07 mini cooper non-s model. automatic transmission and hits 71k.
Old Oct 28, 2012 | 02:40 PM
Porthos's Avatar
Porthos
Might be the mounts but, it could also be a bunch of other things too.
Old Oct 28, 2012 | 07:45 PM
yyj3869's Avatar
yyj3869
any more suggestions?
Old Nov 3, 2012 | 02:59 PM
yyj3869's Avatar
yyj3869
i just visited local mini specialist for asking my problem. He said it might be that i didnt use premium gas. Of course, i didnt use premium since i moved to california from new jersey because the gas price in cali is too high..,anyway the question is.. does it really make difference? does it really relate to idle?
Old Nov 3, 2012 | 03:45 PM
Martin Brenneke's Avatar
Martin Brenneke
shakes at idle
Yes if the manual says premium,then use it. There must be a reason, as I believe yor engine Has High Compression. Also would throw a can of Seafoam in gas tank to help clean internals. Shoul run better after new at least 91 octane.
Old Nov 3, 2012 | 03:57 PM
yyj3869's Avatar
yyj3869
is it okay to put chevron fuel system cleaner instead?
Old Nov 3, 2012 | 05:01 PM
sumint's Avatar
sumint
Do you have any mods? I had NM Engineering Engine Torque Arm Mount Insert and it would intermittently cause a vibration at idle. I removed it and the idle vibration has not come back (5k miles since removal).
Old Nov 3, 2012 | 06:46 PM
yyj3869's Avatar
yyj3869
nope, no mods and nothing aftermarket
Old Nov 11, 2012 | 07:39 PM
yyj3869's Avatar
yyj3869
damn....what the hell is the problem...
Old Nov 11, 2012 | 08:15 PM
RobMuntean's Avatar
RobMuntean
mounts definitely sounds like your issue.
Old Nov 12, 2012 | 03:26 AM
Fastlane's Avatar
Fastlane
A rough idle could be caused by bad/fouled spark plugs. I believe the change interval for plugs is 100k miles on the justa, but 70k is a lot of miles and its possible they are done now, especially if lower octane fuel has been used. Might be worth changing them out as they will be due soon anyway. Good luck!
scfiveo
Sep 27, 2019 02:27 PM
navybsn
Oct 4, 2015 03:27 PM
Miniwaukee
Sep 29, 2015 09:22 AM
jennster
Sep 28, 2015 06:19 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
