Thermostat Replacement "HOW TO"???
Old Oct 27, 2012 | 02:02 PM
eddie-saavedra's Avatar
eddie-saavedra
Hi, just wondering if there is any good "how to" on replacing the thermostat housing in my (r53) 2006 cooper s? Iv looked and can't seem to find a good one, and i am in desperate need
Old Oct 27, 2012 | 02:54 PM
ACallahan's Avatar
ACallahan
Do a search on this forum if you have no luck I have a do it yourself on this with pictures and all from another Mini forum. PM me for it.
Old Oct 27, 2012 | 04:20 PM
ViperNL's Avatar
ViperNL
I usually use google to find posts on here, for some reason the forum search is not too good. This is the one I used a couple of weeks ago:
https://www.northamericanmotoring.co...at-change.html
Pease keep reading that thread for at least 2 pages, there's some useful tips in there, so you won't have to take the ecu out for example.
Old Oct 29, 2012 | 09:17 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Hopefully this helps a bit: http://www.pelicanparts.com/techarti...eplacement.htm
888.280.7799 | 6am - 5pm PST
Old Oct 29, 2012 | 03:38 PM
LLZuB's Avatar
LLZuB
It's quite simple. I used pelicanparts writeup.
-Remove the air box completely
-Remove Map sensor/bracket
-Remove 3 bolts on Theromostat housing
-Replace Thermostat/gasket
-Reassemble
I just did this recently, only problem I ran into was rusted Map sensor screws which needed to be drilled out
Cereall
Sep 5, 2019 06:05 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
scottrn
Aug 22, 2015 07:26 PM
PSIChocolate
Aug 13, 2015 12:46 PM
kwijmbo
Aug 5, 2015 09:00 PM
